Tuned '13 trucks, what your pushing for boost? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 10 Old 06-27-2013, 09:27 PM Thread Starter
Just curious as to what you '13 models are getting for turbo boost. I cant seem to get mine up over 23-24 psi, and I am running SPE tunes and everything. I am at altitude however, 5300', which will make some difference.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #2 of 10 Old 06-28-2013, 07:50 AM
Jeremy@NoLimit's Avatar
Quoted: 75 Post(s)
Mine is about the same. Remember, boost pressure is a restriction. Your goal isn't to see how high you can get the pressure. Its to make sure you are using the pressure available efficiently.
Jeremy
-Jeremy- No Limit Fab
Jeremy@nolimitdiesel.com
Sp@rtan, SCT, GH, PIP, H&S
Orders-1 800 581 8986
My direct line (706)549-5355
(706)988-6142 call or text
".org5" coupon code/discount for powerstroke.org members!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@NoLimit is offline
post #3 of 10 Old 06-28-2013, 07:56 AM Thread Starter
From Dan @ SPE:
"Kris, I have the boost set a bit lower for the 13 trucks to help keep the turbos together, also the elevation doesnt help. Its limited because at higher boost levels the drive pressure goes through the roof and gets very inefficient. They do drop volume but the air is not as hot. Its a give and take kind of thing. Boost does not necessarily mean horsepower." I guess the lower boost is due to his tuning.
highdrum is offline
post #4 of 10 Old 06-28-2013, 09:28 AM
Zack birge's Avatar
I'm running 23-24 on SPE tune
'15 F-250 Platinum CC/SB Black
Just a couple go fast goodies!
PPEI Tuned, No Limit Fabrication goodies, 5" FloPro
22x12 Rockstar 2'w 35" Terra Grappler G2's
Zack birge is offline
post #5 of 10 Old 06-28-2013, 01:00 PM Thread Starter
Zack, what are you getting with Eric from innovative's tunes?
highdrum is offline
post #6 of 10 Old 06-29-2013, 04:04 AM
Zack birge's Avatar
Still patiently waiting on it! Will let you know asap
post #7 of 10 Old 06-29-2013, 06:17 AM
2013F250Tank's Avatar
Running H&S 26 psi max here.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #8 of 10 Old 06-30-2013, 06:28 AM
i just got my mini max race tuner for my 2013 f350 with the unlock codes how do i update the tuner. do i just have to download the full sd card for the 2013
08 F350 Fx4 cc sb 4" downpipe back exhuast dpf deleted afe intake w/ H&S minimax tuner R.I.P.
2013 F350 Platinum edition
nystrokin516 is offline
post #9 of 10 Old 06-30-2013, 06:45 AM
2013 tuning limits boost to 26 psi.
The vane position is at 2% where on the older tunes it is at about 15%.
FWIW This amount of boost is similar to our turbo saver tunes we have been sending out for a few months now.
We have gotten a few calls on this and we confirmed with H & S, 26 is the correct amount of boost on the 2013.
cfd_shop is offline
post #10 of 10 Old 06-30-2013, 09:00 AM Thread Starter
Yes, take the micro sd out of the tuner, put it into the adapter, and plug the adapter into your usb port on the computer, then just run the H%S updater on their website.
highdrum is offline
