SPE HOT-X tune - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 29 Old 06-14-2013, 09:13 PM Thread Starter
SingleCabStroker's Avatar
SPE HOT-X tune
So to do the tune or not to. I have been hearing ranting and raving over this tune. I also have a single cab and wanna see the power this tune can pull. Whats all included and whats everyones feelings/wisdom on a tune of this magnitude?
SingleCabStroker is offline
post #2 of 29 Old 06-15-2013, 10:44 AM
Do it. I've had it for two weeks and there isn't anything better out there. I went with the wild trans tuning; I would say it takes H&S trans tuning and one ups it. The power is always there at all throttle positions. If your not a fan of smoke, you won't be happy there. I don't mind it. '12 Lariat Ccsb fx4, K&N cai, sinister egr delete, MBRP 5" straight, mini max. Best 1/4 mile according to my mini was 13.7 spinning all 4 tires. 5.2 to 60. I'd imagine in your single cab it'll be pretty hard to keep tires on it.
orstad21 is offline
post #3 of 29 Old 06-15-2013, 01:44 PM
Hot x was tempting til I blew the turbo with h&s hot. I imagine the spe hot x will be even harder on one
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #4 of 29 Old 06-15-2013, 02:31 PM
Lf83's Avatar
^^^ whs
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #5 of 29 Old 06-16-2013, 07:40 AM Thread Starter
That's not necessarily true. That's alot of different setting you can tweak. Did either of you actually have it on your truck?
post #6 of 29 Old 06-16-2013, 08:01 AM
You think the extra 50hp is magical?
jcain is offline
post #7 of 29 Old 06-16-2013, 08:36 AM Thread Starter
Obviously magical enough to spend 100$. In my mind its justifiable, in your mind obviously not. But then again I don't have all the stuff to strain my turbo such *** added dead wait like yourself.
post #8 of 29 Old 06-16-2013, 08:39 AM Thread Starter
That exactly what I wanted to hear! How many miles have you put on it? It not meant to tow, just performance. How's tranny? Pretty firm?
post #9 of 29 Old 06-16-2013, 10:11 AM
I'm almost at 18,000 on the truck. I would say around 12,000 tuned and deleted. SPE Hot X about 3,000... I haven't pulled anything with my truck, well I pulled a jeep out of a swamp, but thats it.
The tranny, I would like to use the word firm, not a bad firm though. Torque Converter lock up is very fast. Shifts are also faster. I do notice it shifts up a gear at slightly lower speeds. In other words I can run 6th in drive at 44-45 mph.
There is a small amount more turbo lag off the line, and smoke, but it's all made up in the end when the turbo spools up. I had my defuel set for 32 psi and would hit it just going up a hill at 1/4 throttle, in a high gear. I bumped it up to 34 psi and haven't hit it yet... (no comments from the peanut gallery about where I choose to set things on my truck please)
I have yet to defuel for egt's, that's set at 1350... I will recommend this tune any chance I get to anyone on the fence about getting it.
orstad21 is offline
post #10 of 29 Old 06-16-2013, 10:24 AM
That made a bunch of sense. You sound pretty intelligent. I bet we could have a real fact-infused conversation with that sort of dribble. Any how, since you couldn't coherently decipher my post I suppose I could do it for you. That 50hp that spe makes over h&s will come at a price, either total timing advance increased or more fuel and boost. The former puts your stock rods at risk and the latter puts the already suspect turbo at risk. I'm betting it's the latter. In which case my turbo chunked with the lesser H&s tune so I fathomed the spe to be more risky.
jcain is offline
