6.7 PSD tuner with warranty - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 6 Old 06-12-2013, 10:13 PM Thread Starter
TEXAN AVIATOR's Avatar
I did some searching and pulled up nothing. I'm sure I'm missing something with my search but regardless...
Is there a delete kit I could install then remove for warranty work or can Ford see what has been done. Talking either a 2012 or 2012 PSD here.
TEXAN AVIATOR is offline
post #2 of 6 Old 06-13-2013, 05:34 AM
Axis2011KR's Avatar
Ford can tell it's been tuned by looking at the checksum I believe in the ECU even if you've turned everything back to stock if they really wanted to be a stickler about it.
You've got to pay to play so if you delete just own up to the risk that you might have to replace parts of something breaks. The things that are breaking on tuned trucks are breaking on stock trucks for no reason generally like turbo failures and are about 2-3k to replace if it happens which isn't too bad. If you tune it, don't turn the boost up past 33psi because that seems to be the safe point...a lot of the tuned trucks with turbo failures have been on MCC custom tunes with higher boost up to 38psi in some cases and it seems the stock turbo isn't meant for that high of boost regularly.
2015 F-250 King Ranch 6.7L CC FX-4
Fabtech 10" 4 Link with Coilovers/American Force Vector 22x12/Toyo MT 40x15.50x22
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
Axis2011KR is offline
post #3 of 6 Old 06-13-2013, 07:47 PM
Randy_270's Avatar
Quoted: 2 Post(s)
From what I understand, even if the tuner removes the "footprint" so the dealer cant tell its been tuned (as people say Spartan tuners do) they can still check how many regens the truck has gone through and compare it to the mileage. For example, if you got 50k miles on you truck and only 10-20 regens well then they obviously know that somethings been done to the truck
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #4 of 6 Old 06-13-2013, 07:52 PM
Mob boss
Jarrod B's Avatar
Quoted: 148 Post(s)
is there a way to fool the number of regens in the ecm?
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
http://www.powerstroke.org/forum/lon...-powerstrokes/
Jarrod B is offline
post #5 of 6 Old 06-14-2013, 11:59 AM Thread Starter
Hmmm ok. Is anyone running a straight pipe with dpf on? How does that sound? I've been looking for a video of that.
post #6 of 6 Old 06-14-2013, 12:27 PM
An exhaust with DPF on is just for looks. No power and no sound increase.
For Sale: 2013 Lariat Ultimate CCSB 15K miles
3.55 ELD, Tinted, AMP setps, Retrax Pro, Two Spot Rigid D2 Dually's, Two Flood Rigid D2 Dually's, Fabtech 6in lift, Billstein struts, Dual Pro Comp Steering Stabilizers, 20in XD Addicts, 37x13.5x20 Toyo M/T, Line-X, Diversi-Tech 12" drop hitch, H&S Mini Maxx, 5in Flo Pro, H&S EGR delete, S&B CAI
FMKeith is offline
