EGR Blockers, broken bolt - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 20 Old 06-02-2013, 12:03 PM Thread Starter
Hey guys,
Went to put on my blocker plates today and the right bolt on the exhaust portion of the EGR pipe broke off. The bolt was 1/2-3/4 of the way out when it broke. Spent a handful of hours today trying to get the bolt out. It's loose in the threads, but it won't progress any further loosening. About 1/4 inch is sticking up and out of the hole. Not a whole lot of room to work. Can't really get a drill down in there. I don't have the tools or expertise to really do much of anything. I put some silicon on the H&S plate with the EGT sensor in it and bolted it down with the 1 remaining bolt expecting to be able to take it to a nearby shop where they can remove it for me. Will I be able to drive it to the shop like this? Or will there be too much pressure and break the other bolt etc? Suggestions?
2011 F-350 CC SRW SWB Lariat, Tuxedo Black
H&S Mini Maxx, aFe 4" alum, H&S EGR Delete, S&B CAI
BonzTM is offline
post #2 of 20 Old 06-02-2013, 12:30 PM
There shouldn't be really any pressure you'd have to worry about. Just snug fit the other bolt on, and drive it like that to get the other bolt removed.
2012 F-350 supercab long bed srw lariat tuxedo black
MBRP 5" dp-back exhaust (thermal coated) with RBP 6" tip, AFE pro-dry s cold air intake, H&S mini maxx, H&S EGR delete, RBP rx3 nerf bars, RBP fender emblems, RBP rx2 grille with color matched grille surround, AMI color matched locking fuel lid
Soon to install..
RBP rear bumper, RBP front winch bumper w/ Warn 16.5ti, Icon 4.5" stage 3 suspension, Icon steering stabilizer/shocks, 35"x12.5" nitto trail grapplers, RBP Revolver 20" wheels
theinfamouskonrad is offline
post #3 of 20 Old 06-02-2013, 03:16 PM
Pull up EBP on the h and s display that will be the pressure that is on it.
Get a 110 welder and put a nut over the bolt, than weld the nut on it.
Cover the manifold and other parts to keep debris contained.
Hope this helps.
FWIW there was a member on here last week that complained he blew his blocker plate off because one of the bolts was not tight.
cfd_shop is offline
post #4 of 20 Old 06-08-2013, 10:41 PM
I had the same luck doing my plates, a welder plus a couple washers and nuts did the trick.
Rodzilla is offline
post #5 of 20 Old 06-11-2013, 07:07 PM
What are yall using to remove the bolts? Ratchet or impact?
I have broke too many bolts with a ratchet learning my lesson a long time ago. After reading about this issue I used my baby impact. I will say I bumped them in forward a bit then went to revers and had no issues.
sleepersilverado is offline
post #6 of 20 Old 06-12-2013, 04:26 AM
Add heat to the bolt then try
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #7 of 20 Old 09-03-2013, 05:53 PM
generalee31184's Avatar
Send a message via AIM to generalee31184
How the heck do you even get in there to weld a nut on. I just rounded one of mine off today while trying to remove.
generalee31184 is offline
post #8 of 20 Old 09-03-2013, 05:54 PM Thread Starter
I couldn't get it off. I took it up the street to a guy who did everything he could to get it out. He finally ended up drilling it out.
BonzTM is offline
post #9 of 20 Old 09-03-2013, 06:14 PM
I thought about that too but do not see how I would ever get a drill in there as its not a straight shot.
post #10 of 20 Old 09-03-2013, 06:15 PM Thread Starter
He had to take part of the intake manifold off to get a straight shot.
BonzTM is offline
The Following User Says Thank You to BonzTM For This Useful Post:
Derek T444E (08-21-2014)
