carli coilover - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 9 Old 05-14-2013, 12:14 PM Thread Starter
hollywood1983's Avatar
carli coilover
Who is running this lift? How does it ride? Is it easy to adjust the lift height? Will it fit 37x13.50 r20? I have the bmf 20x9 novakanes on mt truck now, I want to get the lift but I dont want rubbing issues. Just need some more info on the lift from the consumer stand point before I pull the trigger. I really didnt want to spend this much money, but I am keeping the truck for awhile and why not settle for nothing but the best. Thanks
2012 f250 fx4 lariat ultimate
2.5 ready lift stage 3
20x9 novakane wheels
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
Egr block off plates
hollywood1983 is offline
post #2 of 9 Old 05-14-2013, 01:12 PM
OCVeloMan's Avatar
Quoted: 118 Post(s)
Garage
I'll let customers chime in as to the ride and who's running it but yes, it's easy to adjust the height but we do not recommend doing it as the height is set and the components in the kit are all built around a 4.5" lift height. It will fit the 37" tire so long as your wheel is no more than 9" wide with 5-5.5" of backspacing.
You may get better response posting this in the suspension section! Good luck with your build!
OCVeloMan is offline
post #3 of 9 Old 05-14-2013, 04:28 PM Thread Starter
Thanks oc I just want to know if ajusting the coilover will mess them up or effect the ride quality. Also will carli build my a 6" system or can you get one?
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #4 of 9 Old 05-15-2013, 07:29 AM
OCVeloMan's Avatar
Quoted: 118 Post(s)
Garage
We currently do not have plans to build a 6" as our 4.5" is more like a 5" in all actuality. It allows for the same tire fitment as a 6" but the 6" becomes much more involved. Adjusting the coilover to 6" will basically max out your steering linkage and heim on the track bar. We do not recommend it and you'll lose 1.5" of down travel as well.
post #5 of 9 Old 05-15-2013, 07:49 AM Thread Starter
Thanks again oc im just concerned w tire fitment and rubbing issues w thw 4.5" system. Before I get this lift I want to know if this will work for my application running the 37x13.50r20.
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #6 of 9 Old 05-15-2013, 08:00 AM
OCVeloMan's Avatar
Quoted: 118 Post(s)
Garage
No problem, as stated in my second post "It will fit the 37" tire so long as your wheel is no more than 9" wide with 5-5.5" of backspacing."
post #7 of 9 Old 05-15-2013, 09:47 AM Thread Starter
Thanks again oc now to choose the coilover or pintop. Which one rides better more on the highway vs offroad?
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #8 of 9 Old 05-15-2013, 10:21 AM
OCVeloMan's Avatar
Quoted: 118 Post(s)
Garage
They ride identical. The only reason to get the coilover over the pintop would be for the height adjustability or to run bypass shocks with it. Otherwise, you can get a pintop system with stainless steel shafts and full leaf springs for less than the price you'd pay for a coilover that has standard shafts and add-a-packs. Plus, the pintop will ride much better and be more reliable in the above configuration.
post #9 of 9 Old 05-15-2013, 10:23 AM
Skyd Ram's Avatar
Quoted: 65 Post(s)
Those BMF's have a 5" backspace so with those tires you will clear the body but you will need to pull the plastic inner liner back an inch which is super easy. You will also touch the outer bumper bracket in the front which you can either trim,remove, or space the bumper forward about .25-.5".
I would suggest the full leaf option for the rear to center the axle in the wheel well in addition to the superior ride and elimination of the lift blocks.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
