EGT Monitor YES/NO - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 4 Old 04-20-2013, 10:08 AM Thread Starter
EGT Monitor YES/NO
Recently tuned and deleted 2012 6.7. Using H&S Mini Max..
Question Is it nessassary to monitor your EGT's with H&S provided tunes. Towing small trailer 2000 miles in one week do not want to damage.
Ford_Power12 is offline
post #2 of 4 Old 04-20-2013, 10:42 AM
jrshelton13's Avatar
I am sort of in the same boat. I do not have the egr delete which obviously doesn't allow me to monitor the egt's. But I have read as long as you are not really pushing the truck hard the temp's should not reach a dangerous level. I know there are a lot of other owners on here that can really give you/us a better idea of the temperature range and with how hard the truck was working. But in your case I don't think there is too much to worry about. I will be towing about a 3k pound trailer 600 miles in a few weeks, I don't think the truck will even break a sweat, at least not enough to really get the egt's to a dangerous level.
But I would like to hear from others too in regards to their own opinions/experiences in similar situations.
jrshelton13 is offline
post #3 of 4 Old 04-20-2013, 11:49 AM
Quoted: 30 Post(s)
Keep it in Tow(50hp) and you'll be fine.
Towing my 29' Everglades(12,000#) My EGT's are 600-800*F depending at what speed im cruising. I hit 1,100*F while running up a bridge. Taking off from a redlight they are about 600-750*F(running 2,000 rpm). You really have to try to get over 1000*F. Anything under 50% throttle your going to be fine. 2-4,000# is literally nothing for this truck.
H&S MinniMaxx
5" Flo-Pro
S&B Intake
Carli 2.5" Backcountry w/Full Leafs
Balla6.7 is offline
post #4 of 4 Old 04-20-2013, 11:52 AM
Tweeter1388's Avatar
get the EGR blocking plates... pretty cheap and you can install the probe.. worth it for sure
DIRTY SOUTH STROKERS
2012 F-250 6.7 Powerstroke
10 inch Fabtech lift
40x15.50R20 Toyo MT
20x14 XD Riots
Amp Research Steps
H&S Mini-Maxx
S&B intake
4 in Flo Pro
EGR Block Plates
Tweeter1388 is offline
