H&S Tire size recal, now CEL - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 4 Old 04-15-2013, 10:35 AM Thread Starter
I put new 35" Toyos on my 11 this weekend, and went to recalibrate the tire size with the MM. Immediately, a "Service Advanc Trac" warning came up, it went away, but now the CEL remains. There are no warning under the system check. How do I get rid of the CEL? Thanks!
cmb396 is offline
post #2 of 4 Old 04-15-2013, 11:37 AM Thread Starter
nevermind, it went away...
Would like an answer from H&S tho as to why it happened?
cmb396 is offline
post #3 of 4 Old 04-15-2013, 11:48 AM
The firmware on your H&S product should NOT allow you outside of around 31-34" tire size range. If, for some reason, your firmware allowed outside of this range, please set it back inside.
This is the factory limitation of what the ABS will allow for tire size setting. We are looking into a work around, but at this time we are limited to the same sizes that can be programmed with the OEM tools.
H&S Tech is offline
post #4 of 4 Old 04-15-2013, 02:16 PM Thread Starter
Thanks for chiming in! My MM let me go up to 34.7, which is what my Toyos are, so I stopped there. I just put it back to 32" and it was fine.
cmb396 is offline
