Delete?? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 5 Old 04-09-2013, 10:14 AM Thread Starter
Delete??
I apologize if this is redundant but I've been combing the forums and reading what I can about a "Delete" but I'm still a little confused. The word delete seems to be used as a general term, I'm wondering what exactly does it mean to Delete your truck? What does it entail in parts ect? And does it require a tuner? I really don't want to jeopardize my warranty.
2011 F-350 13k miles..
mjz52 is offline
post #2 of 5 Old 04-09-2013, 10:20 AM
kirbybc12's Avatar
Deleting would refer to removing your dpf and EGR emissions systems. Doing that requires a tuner. Most dealers don't mind warrantying minor issues while you are deleted, larger engine repairs require a ford engineer to read your ECM, which will find out if you have tuned or not and void that warranty work.
2012 F-350 Lariat FX4 CCSB
2.5" Carli Commuter
Carli High Mount Steering Stabilizer
AFE Cold Air Intake
Truxedo Lo Pro QT
Line-X
Dura-Flap Mud Flaps
Timbren SES
High Idle
35x12.5x20 Toyo AT II Extreme
H&S Mini Maxx, 4" AFE Turbo Back
kirbybc12 is offline
post #3 of 5 Old 04-09-2013, 10:30 AM
It's short/slang for deleting certain emission reduction apparatus's. In your case it would be/may be the EGR and it's cooler, the catalytic converter and/or the diesel particulate filter. The parts involved are pipes and tubing used to replace the item of interest. A tuner would be required in your case if you deleted the DPF( diesel particle filter), and does void warranties if found. Also a slight(pun) EPA violation
2006 built 05/05 XLT CC DRW PSD. Captain chairs, sunroof, polished aluminum wheels, 6speed, manual 4x4. 285K miles with 130K problem free miles on new engine.
RatherBNtheWoods is offline
post #4 of 5 Old 04-09-2013, 11:17 AM Thread Starter
I see, so I understand that removing the DPF would increase performance and raise the exhaust noise level I assume. What are the benefits of deleting the EGR system?
mjz52 is offline
post #5 of 5 Old 04-09-2013, 12:47 PM
SingleCabStroker's Avatar
Huge amounts of awesomeness.
SingleCabStroker is offline
