Sensors plugged into Dpf - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 11 Old 04-08-2013, 06:48 PM Thread Starter
SingleCabStroker's Avatar
Exclamation Sensors plugged into Dpf
So I am planning on deleting my 6.7l... i havnt been under the truck yet to look at the dpf exhaust completely. But from what i hear there are three sensors plugged into that dpf. When i take off that dpf and straight pipe the truck what happens to the sensors and harness? Do they just unplug... should i tuck them up and away from everything once the straight pipe is on? What do i do?
SingleCabStroker is offline
post #2 of 11 Old 04-08-2013, 06:52 PM
they unplug from the dpf there is also a couple egt gauges than u can use with H&s delete or block off plates . and all of the wiring is tied into the fram by connectors etc just zip tie it up and out of the way . it is not a bad ordeal at all 2 hours tops wd-40 and a basic set of ratchets and ur done .
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #3 of 11 Old 04-08-2013, 06:54 PM
they are EGT(exhaust gas temperature) sensors, the truck uses them to regulate DPF and REGEN. If you just unhook them the truck may not start unless you get them tuned out. I work at a ford garage but have never deleted them, just replaced them. Have fun getting them out by the way lol
1fastblackz is offline
post #4 of 11 Old 04-08-2013, 07:15 PM
there not bad unhook them from the wire bundle and while u have on the ground were they are easy to get to unscrew one and screw it onto ur egr blocker plate.
lhood6.7 is offline
post #5 of 11 Old 04-08-2013, 07:36 PM Thread Starter
Yeah i have my H&S tuner which is gonna delete everything. I just wanna know what i do with all the unplugged stuff lol. Tuck and roll or what? haha
post #6 of 11 Old 04-08-2013, 07:54 PM
basically make it need and clean lol its simple i did the dpf delete with a crawler and a couple wrenches and the egr blocker plates with even less lol when u do the tuning be sure to unplug BOTH egr connections there is one the egr it self its orange cant miss it and the other is on the drivers side under the intake its a smaller plug still orange be sure both get unplugged to prevent damage to the butterfly valve
lhood6.7 is offline
post #7 of 11 Old 04-08-2013, 08:02 PM
just unplug them and leave them in the exhaust. Wrap the ends from the truck with some electrical tape. H&S was thinking of making dummy plugs for the ends to keep them clean, but I don't think it happened. There are more than three, I think 7.
2011 F-350 CCSB
powerstroke43 is offline
post #8 of 11 Old 04-08-2013, 08:05 PM
there is 3 egt sensors plus all the others and ya i wraped the ends of mine with a walmart bag and put all the sensors in a bag etc
lhood6.7 is offline
post #9 of 11 Old 04-09-2013, 05:46 AM Thread Starter
So pretty much what I have gotten is unplug them, wrap em with something to keep em clean and zip tie/tuck em away from everything, then obviously unplug egr, then tune h&s delete? I'm not doing a egr blocking plates. Ill prob tap exhaust manifold instead. Or whatever is recommended.
post #10 of 11 Old 04-09-2013, 06:28 AM Thread Starter
Also what do i do with the DEF system plugged in the DPF? Once i get it off that is?
