Will 6.4 Delete Pipe work on a 6.7? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 5 Old 04-03-2013, 03:04 PM Thread Starter
white07's Avatar
does anyone know if the delete pipe and DPF back exhaust kit from a 2010 6.4 will work on a 2012 6.7? I have a 5" delete pipe and 5" DPF back exhaust kit that I took off of my 2010 before I traded it so I'm curious if it will work. thanks
2001 Estate Green Metallic Limited Excursion w/ 7.3L and 2012 White Platinum Metallic Tri-Coat King Ranch F250 w/ 6.7L
white07 is offline
post #2 of 5 Old 04-03-2013, 03:06 PM
curious about this idk why but i am
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #3 of 5 Old 04-03-2013, 03:07 PM
05_PSD_Erik's Avatar
No. Or at least not easily, the 6.7 delete pipe is a good bit longer due to the UREA segment
Can it work? Yes, with some work and extra pipe
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #4 of 5 Old 04-03-2013, 06:04 PM
the delete pipe by itself, no, it won't fit, but with the dpf back portion, maybe. You wouldn't need any extra pipe, the truck isn't any longer than a 2010. Just check where the flanges bolt up and see if they are the same. Might have to drill some new holes for the hangers.
2011 F-350 CCSB
powerstroke43 is offline
post #5 of 5 Old 04-05-2013, 07:22 PM
It is same length.....hangers are the same from the dpf back. 6.7 has 3 hangers from down pipe to end of dpf, 6.4 only 1 or 2 can't remember. Any ways the front hanger is (1st 1 back from down pipe) is 1 ft off. It'll work just gotta re drill hole for hanger or have a new hanger welded on.
jayz is offline
