High egt's - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 14 Old 03-31-2013, 01:14 PM Thread Starter
High egt's
2012 ccsb 4x4 3.31s, h&s tuner on performance, mbrp dpf delete and egr delete. The truck will hit defuel (1450) by the top of 2nd or bottom 3rd if I'm lucky. How is anyone making a full 1/4mile pull at this rate?
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #2 of 14 Old 03-31-2013, 03:23 PM
hollywood1983's Avatar
Did your egr delete come w a bung that goes to the exhaust msnifold plate?
2012 f250 fx4 lariat ultimate
2.5 ready lift stage 3
20x9 novakane wheels
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
Egr block off plates
hollywood1983 is offline
post #3 of 14 Old 03-31-2013, 03:24 PM Thread Starter
Originally Posted by hollywood1983 View Post
First did you use the block plates and removed the longer egr pipe that goes to the exhaust manifold? If not your egts are going to be super high due to the fact that it is reading exhuast after the turbo and not pre.
Full egr removal including pipes. Egt probe is right off the manifold now
jcain is offline
post #4 of 14 Old 03-31-2013, 04:19 PM
Only time I have came close was on hot tune wide open
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #5 of 14 Old 03-31-2013, 04:43 PM Thread Starter
I don't know anyone that'd goto the track on tow tune at half throttle
jcain is offline
post #6 of 14 Old 03-31-2013, 07:30 PM
bbc109758's Avatar
Are you useing h&s pyro or off old exhaust. 2 settings on mini and 2 pyro spots on mini. I would check those first and also possible bad sensor. My guess still a newb.
bbc109758 is offline
post #7 of 14 Old 03-31-2013, 08:48 PM
What pyro are you using on your manifold? I use the stock on so my pyro on the mini is set to pyro one, if you have the h&s pyro it is pyro 2 setting. Need more info on this
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #8 of 14 Old 03-31-2013, 09:06 PM Thread Starter
H&s adapter plate with a relocated stock pyro. and the mini is on pyro 1. pyro 2 gives erroneous readings like 2500 at idle. My cruise egts are 5-600.
jcain is offline
post #9 of 14 Old 03-31-2013, 09:20 PM
Ok, I have never defueled my egt setting but I havent made a 1\4 mile run. I know I had mine on performance setting getting onto the interstate punched it hit 1250 on my egt thats going from 1st to 5th. So cruising speed thats what mine reads. So I dont think there is anything wrong w the pyro. I dunno all sounds norm to me, but hitting that at 2nd I dunno.
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #10 of 14 Old 04-30-2013, 09:08 PM
mpichner's Avatar
You figure anything out with your truck? I can run wot all the way to 100 mph and not break 1350 degrees. Wonder if something is up with tuning or for some reason you have serious air flow restrictions
11 F350 6.7 Lariat ultimate cc short, HS Mini Maxx, 5" Flo-pro, 3" rough country lift, lock picked, gooseneck hitch, air lift bags, recon strobes (tow rig/ toy)
06 Jetta TDI, Malone tuning +30hp, egr/ shutter valve delete (work comuter)
05 F250 6.0 Lariat cc short, Banks Big Hoss bundle, gooseneck, leveling kit, black moto 951s, (SOLD)
99.5 F250 7.3 cc short, 8" skyjacker, traction bars, Banks powerpack system stacked with 6 gun, (SOLD)
mpichner is offline
