Removing actual DPF - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 12 Old 03-29-2013, 01:24 PM Thread Starter
Jointasset's Avatar
Quoted: 5 Post(s)
Removing actual DPF
I am in the middle of removing my DPF(everything back from the DPF is off) and I notice that the nuts are welded to the flange where the dpf connects to the downpipe. Anybody else have this? Any suggestions to loosen them or get the DPF off? Thanks in advance
2012 F250 leveled w 295/60/20 Terra Grapplers on Fuel Throttles. Titan 50 gal. Dynamat,JL Audio. 5" MBRP, S&B
2002 Excursion 7.3- WW2, EBPV delete, PHP Hydra, CNC 4 Line Feed/hpop/hpx lines,4" MBRP, s&b, 6.0 trans cooler, bellowed up pipes, hutch,CTS2,Helwig,JWVB
Jointasset is offline
post #2 of 12 Old 03-29-2013, 01:26 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Cut the stud?
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 12 Old 03-29-2013, 01:51 PM
Hawkeye Diesel's Avatar
Wrench on the bolt, it turns. Nuts are only welded to the flange on the inlet of the emissions garbage
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #4 of 12 Old 03-29-2013, 02:07 PM
What hawkeye said.. I did the same thing as you and worked on breaking the tac weld and realized that the bolt is not the same as the others and spins freely.
2012 F-350 CC SB Sterling Grey 4x4.... Flo-Pro 5", Spartan Warhammer....
Too Come.. lift, wheels, tires
Pjosh6 is offline
post #5 of 12 Old 03-29-2013, 02:12 PM
PowerStrokePete's Avatar
I had that same problem, I used my Impact wrench and broke the first nut off. Do what they said and remove the bolts.
[IMG][/IMG]
2011 F-250 SCLB XLT 6.7 Powerstroke
-H&S Minimaxx
-H&S EGR Delete
-Airaid intake
-Fisher 8.5' Xtreme V SS
-High idle switch
-Firestone Airbags
-Tuff Country 2.5" leveling kit
-Ready Lift 4" rear blocks
-Dick Cepek DC-2 18x9, 35x12.5R18 Toyo A/T II
-20% Tint
-Pro Rack
2015 Mustang GT 50th Anniversary #1310 of 1964.
PowerStrokePete is offline
post #6 of 12 Old 03-29-2013, 03:56 PM Thread Starter
Jointasset's Avatar
Quoted: 5 Post(s)
Thanks guys.....think I was looking for a reason to call it quits for the night. Got the bolts off and sensors disconnected. Now trying to figure out how to get the dpf off the rubber mounts and lower it down by myself. Thinking about putting a floor jack underneath it and working it that way. I'll keep you posted.
post #7 of 12 Old 03-29-2013, 04:08 PM
Quoted: 4 Post(s)
Get a FlashLight and look at the opposite side of the fastener. There's a regular non-welded nut. I used a air ratchet and a swivel attachment.
'11 F350 6.7L FX4,
H&S Tuned & Deleted!
5" Flo-Pro
S&B Intake
Balla6.7 is offline
post #8 of 12 Old 03-29-2013, 04:11 PM
For the rubber mounts I used wd40 and had a strap to balance the weight and worked great.also a pry bar of some sort to push out the hangers.
Pjosh6 is offline
post #9 of 12 Old 03-29-2013, 04:28 PM
HorseMover's Avatar
Quoted: 25 Post(s)
Man I can't wait for for truck to shed a few pounds.
2012 F-350 CC Lariat Dually
HorseMover is offline
post #10 of 12 Old 03-29-2013, 04:28 PM
For the hangers, just remove the brackets from the underside of the body, then mess with the rubber and put the ones youll need back on your truck
