driveline vibes w/10" lift... HELP! - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
post #1 of 12 Old 03-13-2013, 11:59 PM Thread Starter
Those of you with lifted CC LB's what are you using for a rear driveshaft. I lifted my 2011 F350 dually CC LB 10 inches and no matter what I do I can not get rid of this driveline vibration. So far I've tried rotating the pinion up 5 degrees, a custom 1.5 inch transmission drop mount, completely rebuilding the driveshaft and of course shimming the the carrier bearing and nothing seems to help. After doing all that I looked into getting a one piece drive shaft made but no local driveline shop will build me a one piece that long. Some of the guys over on the cummins forum with similiar issues seem be getting away with a one piece without any issues. I am completely at my wits end with this issue. Anyone here have any ideas?
2013 F150 SuperCrew Lariat 4x4 6.2L
Flowmaster catback dual exhaust
6" BDS lift w/ 1.5" Daystar leveling kit, 335/65/R18 Nitto Terra Grapplers
2011 F350 King Ranch Dually 4x4 Diesel
8.5 Skyjacker 4 link Lift w/ 2" leveling kit, 40X13.50 Nittos
2010 Shelby GT500 Coupe
Black/grey stripes
2.3L Eaton S/C, JLT CAI, 65mm CJ TB, Injector Dynamics 725s, JBA offroad exhaust, AFCO dual fan H/E
sask08 is offline
post #2 of 12 Old 03-14-2013, 03:09 AM
My 8" lift came with a 4" drop for drive shaft.....a 1" Drop comes with 6" lifts
I'd say u dont have enough drop. Mine was a cc/sb even pushed that 8" to about 11" with same bracket and never had any vibes.
Look up pmf suspensions......they will get u set up with a completely adjustable drop bracket.
http://www.pmfsuspension.com/Adjusta...cket_p_15.html
jayz is offline
post #3 of 12 Old 03-14-2013, 12:15 PM Thread Starter
I have shimed this situation with as little as an 1" up 3" and it will just not go away. I think 4" would be too much on a long box as the drive shaft is virtually straight right now at the center ujoint, 4" would reverse the driveline angles. I should mention also I carry moderate loads in the truck also which changes the dshaft angles slightly and I've noticed that if its shimmed decently empty it will vibrate like crazy with even a slight load. I really would like to run a one piece driveshaft but would like to know if anyone else has done it.
Black/grey stripes
sask08 is offline
post #4 of 12 Old 03-14-2013, 03:51 PM
BubbaJ's Avatar
Not in a new truck.. But i had a CCLB with around 10"s and after running a 1 Piece shaft.. it took care of all of my vibration..
Uhhh... Wait... What...
2005 F-250 PowerStroke 6.0 ** SOLD***
BubbaJ is offline
post #5 of 12 Old 03-14-2013, 04:00 PM Thread Starter
Any idea what kind of length you were dealing with? Aluminum or steel?
Black/grey stripes
sask08 is offline
post #6 of 12 Old 03-14-2013, 05:00 PM
Are u having a shutter off the line only or vibration at any speeds? I have a bulletproof 12 inch on my cclb 2011 and only shutter on take off then smoothe from there. I know a one piece drive shaft would cure our problems but was not aware they made them that long
dustin schifano is offline
post #7 of 12 Old 03-14-2013, 05:14 PM Thread Starter
I only get the shudder if I shim the bearing less then 2 inches vibration remains through out. I starting to think maybe my driveshaft is out of balance seems alot of people running as big or bigger lifts with little problem.
I would still like to ditch the 2 piece though.
I think I may have found a solution it appears a place in texas makes an 86" one for the dodge guys out of 5 inch aluminum tubing. they have it on trucks dyno'ing 1200 hp so its definitely strong enough. I'm going to look into it. Just have to go out and measure mine to see if thats long enough for a ford.
A good set of traction bars will eliminate the shudder though. I did that on my 08 and it was smooth all the way up to 220km/h.
Black/grey stripes
sask08 is offline
post #8 of 12 Old 03-14-2013, 05:16 PM
BubbaJ's Avatar
I can't remember the company. But there is one here in San Antonio that will do them..
I can't tell you the length, But it was 5" aluminum, Thats the only way he would do it. Wouldn't go any skinnier, or use any other metal..
I wasn't running a diesel, but a 400hp Gaser and I beat the hell out of it in the mud, and never had any problems with it.
I will try and figure out the company name and get it too you.
Would be difficult to ship though.. But i'll see what they say
BubbaJ is offline
post #9 of 12 Old 03-14-2013, 05:19 PM
BubbaJ's Avatar
Found it.. Driveshafts unlimited.. I remember when I had mine done.. It was pricey.. But well worth the wait..
*The source for High Performance Drive Shafts, PTO Shafts, and Aluminum Shafts-Drive Shafts Unlimited Texas
BubbaJ is offline
post #10 of 12 Old 03-14-2013, 05:41 PM Thread Starter
Thanks! I'll give them a shout and see what they have to say.
Black/grey stripes
sask08 is offline
