Want to fit 38x15.5x20's - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 31 Old 03-04-2013, 07:41 PM Thread Starter
Hey guys
Picking up my new 2013 F350 Lariat sometime in the next few weeks. This is my first brand new truck ordered just how I want it, so I'm super pumped!
I've had trucks on 35's and 37's in the past but I want to go a little bigger and a LOT wider. I want to run 38x15.5x20 Toyo's on some Fuel Maverick or Fuel Driller 2-piece wheels. What would it take to fit these under the truck?
The choices for widths/offsets are as follows:
20x10 -19
20x12 -44
20x14 -76
Toyo recommends a 20x12 wheel for the 38x15.50x20, so I'd like to stick with that if possible. 20x14's would be cool but I'm assuming would exacerbate rubbing problems? Would these tires on a BDS or Fabtech 8" lift be okay? I have already ordered Bushwacker fender flares and will be running bulletproof set back mud flaps. I want to keep the stock front bumper, and I really want a setup that will not rub without needing to go with glass fenders or something silly like that. I drive down a lot of lease roads and when I'm not at work this is my daily driver so I do want to be able to make turns in parking lots without rubbing on my fenders.
Thanks for the advice.
Pushin is offline
post #2 of 31 Old 03-04-2013, 09:28 PM
BIG Laing's Avatar
I see your new, so I won't flame you to much...
38's and 40's have been done many times on this site. If you use the search function or explore the threads a bit, you will have all the answers you need.
20x14 would not cause anymore of a rubbing issue since your tires are are 15.5" wide. After a big enough lift, the offset/backspacing is what will cuase them to fit/rub or not. 12" wide with -44 puts the centerline of the wheel in almost the same place as 14" wide with -76. They are only 6mm difference in centerline position...
Also for best results on threads, make sure they are in the right section. This thread would be better in "6.7 exterior" or "General Suspension/Wheels Tires"
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #3 of 31 Old 03-05-2013, 05:40 AM
Feedback Score: 5 reviews
X2..............They will stick out of the fender wheel.... 8" kit will clear but may rub the 4 link or radius arms..Pm me if I can help.
CT Performance, Inc. is offline
post #4 of 31 Old 03-09-2013, 12:07 PM Thread Starter
The only problem with searching is there's so many conflicting results.
"I fit 38x15.5's on a 6" lift" - Forgot to mention he's on an old body style with cutout fender flares.
"I needed an 8" lift plus a 3" spacer to fit" - Leaf spring front end truck
No real concrete information, and not many people with the newest body style, hence why I was posting here.
Pushin is offline
post #5 of 31 Old 03-09-2013, 02:02 PM
BIG Laing's Avatar
Lift kits are still not performance products.
Yep... The search function still works 10" fabtech with 22x14 with 40's
post #6 of 31 Old 03-09-2013, 02:16 PM
Big_Smokey's Avatar
Search engine is good, but no need to be a pain to an easy answer question.
Just answer the thread and there you go. I get what hes saying as some arent as familiar with the site and what to choose from.
Big_Smokey is offline
post #7 of 31 Old 03-09-2013, 05:04 PM
BIG Laing's Avatar
I answered his question to the best of my knowledge in my first post (post #2 in the thread). So for anyone, including you to complain about my answer is BS.
post #8 of 31 Old 03-09-2013, 06:54 PM Thread Starter
Probably need to get your eyes checked there bud.
Hey guys
20x10 -19
20x12 -44
20x14 -76
I even bold'ed the relevant parts. You tell people to search so much that I'm sure you're tired of hearing that word and wouldn't want to do it yourself.
You told me that wheel width shouldn't matter for fitting them under my truck. Which is directly contradictory to everything I've ever read on these or any forums, or experienced in real life. A wider wheel will tend to flatten out the tread pattern and make the shoulders a little bit wide, especially on something like a 15.5" wide tire going from a 10" to a 12" or a 14" wheel. I searched, thanks. You answered, in a way I believe to be incorrect, one third of my question. You're like seeing a doctor for back pain, a headache, and bad gas and he sends me home with rogaine and a link to webMD.
Also, thanks for that post about fitting 40's on a powerstroke that is a show queen, with no mention of how it rides, if it rubs, or if he ever even loads it with anything. That's a visual circle-jerk post, nothing more. He even said in another post that it barely clears. Now, I'm assuming that guy never went over anything more aggressive than a speed bump but if his 40's on a 10" lift barely clear that should obviously bring some doubt to mind if you're thinking about running an 8" lift on 38's, but actually using the truck.
So yes, your answer about wheels when everything I've actually seen is different is BS. If you don't have anything worthwhile to contribute to my post besides "search" or a half-assed answer, **** off.
Pushin is offline
post #9 of 31 Old 03-09-2013, 07:39 PM
BIG Laing's Avatar
Your an idiot, I have forgot more about wheels and tires then you will ever know. I answered what I knew, and suggested you search the rest. Good luck on this site with your attitude.
post #10 of 31 Old 03-09-2013, 08:02 PM
Lf83's Avatar
Rogaine and a link to webmd. Lol. My buddy had 22x11 hostages with 40's on the fab 8" and he rubbed at full lock. Especially when leaving parking lots. Just that little dip to the asphalt. I think he cut about 2" of fender to fix. That was an 11 too.
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
