Carli 2.5 Leveling kit - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
User Tag List
post #1 of 34 Old 02-06-2013, 06:55 PM Thread Starter
So I installed a Carli 2.5 leveling kit, now everytime I hit a bump the front end creaks/squeaks.
Everything is installed right, could just need to break in?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 34 Old 02-07-2013, 03:44 AM
goosegodz's Avatar
I would repost in the suspension forum...Look for the Official Carli Thread....
2013 F250 6.7 ccsb,Carli Pintop 4.5, FUEL Offroad Octane Rims, Toyo MT's 37, Smittybilt light Bar, Rigid D2's, Rigid 20" LED
goosegodz is offline
post #3 of 34 Old 02-07-2013, 03:46 AM
BIG Laing's Avatar
or pm OCVeloMan (?) he seems to be on top of everything.
2013 Lariat Eco-Boost F150 Super Crew 4x4 5K Miles. Max-Tow 3.73's, luxury package
BIG Laing is offline
post #4 of 34 Old 02-07-2013, 04:44 AM
X2 on ocv......but I'm thinking its the track bar end!
Ps...how's the ride? Which kit did you go with?
jayz is offline
post #5 of 34 Old 02-07-2013, 06:21 AM Thread Starter
The ride is great, I wish it lifted it more but oh well. Also install went perfect, very nice kit. WIsh I would figure out this noise...
wreedPS is offline
post #6 of 34 Old 02-07-2013, 07:02 AM
That's great! I'd say wd-40 the spring insolators (rubber between coil and bucket up top) and also the bottom bucket also.
jayz is offline
post #7 of 34 Old 02-07-2013, 08:07 AM
OCVeloMan's Avatar
Quoted: 85 Post(s)
Garage
A creak/squeak could be one of several things pertaining to installation. The track bar will usually not squeak but ensure it's properly torqued on both ends, as is the frame bracket. Double check to ensure there is NO play in your track bar ball joint. Another few things to check, Ensure the coils are properly indexed in the coil seats and the isolators are straight and properly seated.
Many people fail to reset the bushings during installation as well; tis can also cause a squeak. The frame end of the radius arm has a vulcanized bushing. When a leveling system is installed, the bushing is 2" into down-travel bind at ride height. Make sure to loosen the bolt on the frame side bushing to allow the bushing to "unwind" which will set the new center of travel for this bushing. This will ensure the bushing operates as designed throughout up/down travel.
If you're still having issues after all this, know that steering linkage and ball joints are also prone to squeaking. Further, it could be something as simple as the 5100 seals settling/mating to the shock shaft. The shafts are damp from assembly but as the shocks cycle they break in and become less noisy. PM me if you have any issues!
OCVeloMan is offline
post #8 of 34 Old 02-10-2013, 06:38 PM Thread Starter
Sorry I just saw this after I just sent you a email.
Are the coil isolators at the top of the coils? I do believe the coils are properly indexed as I made sure of that when they were installed.
Is there any way to show me a picture of the radius arm bushing I need to loosen? I dont know what you are speaking of.
Thank you!
wreedPS is offline
post #9 of 34 Old 02-11-2013, 07:29 AM
Skyd Ram's Avatar
Quoted: 60 Post(s)
Dan is talkign about the main bolt on each side where the radius arm bolts to the frame bracket.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
8LUG Truck Gear
888-886-2480
Find us on Facebook
Skyd Ram is offline
post #10 of 34 Old 02-11-2013, 08:03 AM Thread Starter
Yes I figured that out. So I just need to loosen and re tighten? Or do I need to compress the suspension a little bit? I guess I could just jump up and down own my big ranch hand bumper..
wreedPS is offline
