| 6.7 Performance Parts Discussion 6.7 Performance Parts Discussion |
Downpipe back w/ muffler sound - flo pro or mbrp
dumb question, but any sound difference at all between the 4" flo pro and mbrp, both with muffler? looking for the quietest one.
thx, |
Don't forget to look at aFe too. I'm very happy with the results.
Had the mbrp dpf back. It's very close to the shock which is a problem with piggybacks and it is not upgradeable to 5" SS Delete if you choose to do so at a later date. aFe's 5" is a true 5" from the downpipe back. Got all my stuff from ptp. Good prices and quick. |
Re: Downpipe back w/ muffler sound - flo pro or mbrp
Got just a delete pipe now and don't like noise level. Debating on a full downpipe back with muffler, but don't know which one is quietest.
Sent from my DROID RAZR using AutoGuide.Com Free App |
another member here mentioned a donaldson muffler, but I'd prefer not to hack up my delete pipe and weld the donaldson in.
Don't mean to be off topic but, what made you decide to come back to the dark side? I was following a couple of your other posts about being deleted, it was really helpful if my decision as well, thank you for that by the way!
what did you end up doing? |
I think that you are doing the right thing and figuring out what works for you and your situation. If you can afford to try out different things and different exhaust and get the best setup for you go for it! Good luck with whatever you decide. There are plenty of helpful people on the .org to point you in the right direction. Also, did you have any issues going back to stock, CEL's, probelms with the tuning, DPF reinstall, anything you would care to share? |
5 cuts to the arm and 30 minutes later, I finally got it without removing the CAT/DPF again. Not counting that, returning to stock was surprisingly easy and fast. Just return mini maxx back to stock then remove aftermarket items. Simple. |
I just used the muffler that was on my stock exhaust pipe. As far as the sound goes, its a perfect blend. Quiet when Im cruising and loud when I get on it....
4" flo-pro dual muffler, quiet as stock, very audible turbo whistle, no drone at any cruising speeds. Loving it!
