turbo boost on h&s mini maxx - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 01-21-2013, 06:56 PM
I'm getting the same boost as stock with my tuner. Around 20 psi. Everything is stock except for the tuner. Is that the most I can get without deletes? I run my truck in mild, but every stage has the same boost.
Old 01-21-2013, 07:17 PM
Re: turbo boost on h&s mini maxx
I believe that is about all you will see with out the DPF delete. The most I saw on Hot setting was 22 psi according to the H&S monitor. Once I put the delete pipe in, WOW! It gets up to 30 psi with a quickness! I set the defuel to 30 psi for now just to be cautious. I hit the defuel almost anytime I take off quick. And the sound of the turbo spooling up is intoxicating! It was well worth it.
Sent from my Galaxy Nexus using AutoGuide.Com Free App
Old 01-22-2013, 02:17 PM
Yea thats about all you will get without deletes. If you do an exhaust in the future you can get around 38 but its hard on your turbo.
Old 01-22-2013, 03:18 PM
38psi^ YIKES!
Old 01-23-2013, 07:12 AM
I've never seen mine break 32-33psi on Hot and that was with 30 degree weather. I believe it's supposed to be around 32psi. Did you hit 38psi towing or something?
Old 01-23-2013, 07:25 AM
Well i have custom tuning. A guy i found on the h and s forum made some adjustment with the mcc program.
Old 01-23-2013, 10:13 AM
I hit 25 undeleted, but that's the most I've seen. Guess Im gonna have to bite the bullet this weekend and put my delete pipes on...gonna be cold!
