| 6.7 Performance Parts Discussion 6.7 Performance Parts Discussion |
H&S defuel
Im now deleted and tuned! I am running H&S MM, 4" flo-pro straight pipe, S&B intake. No EGR delete yet. I set my boost to 32 PSI, hot coolant to 220, cold coolant to 160, and trans to 220. Right now my Pyro1 and Pyro2 is turned off. Should I set Pyro1 without EGR delete kit? Im new to all this.
Also, right now I am running stock transmission tunning. I havent done the transmission relearn yet. The transmission does act funny at times on hot tune. I plan on doing the transmission relearn soon. Should I switch to H&S transmission tuning for the relearn or do you guys prefer stock? |
How are you running stock transmission tuning while tunes with an H&S?
Definitely set up the pyrometer. That's one of the most important gauges. |
during the initial download it gives you the option of h&s transmission tuning or stock transmission tuning. i choose to keep it stock for now. do i just set pyro1 or both pyro1 and pyro2? and what are you setting these at? ive been tempted to run on no power or mild. i bought the tuner in order to do the deletes. really dont want a blown turbo. i have heard anything over 32 psi is a "gray area" for these turbos and people and defueling while set at 32 psi in the wild and hot tunes
Definitely install the H&S transmission tuning. Set up just Pyro 1. These turbos are pretty bulletproof, they can't handle 50 PSI. I have my defuels set at 30 PSI simply because I don't want to push my luck with HG's. If you're running the "No Power" tune, the defuels won't do much for you. When the H&S "defuels", it just shifts into the "No Power" tune. |
I was referring to the 6.4L.
What do you mean by update? Update software or update as in redownload and switch to h&s tranny? My tuner I would think should have latest software. I have only had it a couple weeks.
Like I said, I thought this was in the 6.4L section. Disregard everything I told you.
A lot of time even brand new out of the box there can still be a update available. It depends on how long it has been sitting on the shelf.
