H&S MIni and More - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 12-07-2012, 06:44 PM
H&S MIni and More
i ordered my H&S mini max, mbrp 5" striaight pipe, EGR delete, Pyrometer.
I cant wait to get it all done and i was curious because i wont get time to install it until next week... can i run the tuner stock with the dpf still connected?
Old 12-07-2012, 06:54 PM
Yep, hook it up, go through the download and select DPF present. I ran mine that way for about a week, no problems.
Old 12-07-2012, 07:10 PM
Originally Posted by crazyjatt209 View Post
i got my H&S mini max, mbrp 5" striaight pipe, EGR still waiting on, Pyrometer.
I cant wait to get it all done but its dark and i was curious because i wont get time to install it until monday or tuesday... can i connect the mini max to the truck and not download anything yet and would it still read my trucks information?.. or if i connect it and install the download but leave it on stock would be ok? i just want to see it in the truck for now lol.. any suggestions i can do before i get everything done? truck is stock as of right now... thanks
Why did you buy a pyrometer? You can use one of the stock pyrometers in the EGR block off plate with the mini max... Check out H&S's website for the info.
If you select DPF Deleted you will have a 8000LB paper weight in a couple weeks...
Old 12-12-2012, 07:59 PM
Yah your right!! I'm gunna return the pyrometer I didn't know about it I was just following PTP ordering process but I talked to Eric there and he cleared a lot for me!!
