Electronic rear locker mod?? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 11-08-2012, 09:05 AM
Been searching for a while and havent found anything. Im wondering if there is any way to make the factory locker stay engaged passed 30mph? I know the F150 I had previously with the factory locker had a mod availble where you swap the transfer control case module and the 4wd switch for one from a raptor and the rear axle would lock in 2wd till about 19mph(if i remember correctly) and stay locked in 4hi and 4low till 100mph. Thanks in advance.
Old 11-08-2012, 12:50 PM
Check out SPE's website they have a mod just for what you are wanting.
Old 11-08-2012, 05:59 PM
Spe?
Whats Spe??
Old 11-08-2012, 06:01 PM
SnyderPerformanceEngineering????
Old 11-08-2012, 06:04 PM
Yes....correct
Old 11-08-2012, 07:02 PM
Made In America
Just curious, why would you want that? Sorry new to all this.
Old 11-09-2012, 06:56 AM
It serves as more of a play toy than to serve any real perpose. Its easier to do dougnut and drift with a locker. Plus if he ever wants to pull his truck he will know that the rear is locked giving him more traction. I have one but mine doesnt seem to be working right. It only worked once or twice. Im gana check my wiring and see if thats the problem.
Old 11-09-2012, 07:00 AM
Made In America
Ok that makes sense, so from the factory it will disengage at 30 mph?
Old 11-09-2012, 07:02 AM
Yep. If you try and burnout with it locked the truck will get to 25-30mph and then just die cause the traction control kicks on.
Old 11-09-2012, 07:07 AM
I have one and my only real complaint is that you lose the locker light that comes on when its engaged. So you have to make sure you disengage it when not in use because the light is no longer there to remind you.
Tags
electronic, locker, mod, rear
