| 6.7 Performance Parts Discussion 6.7 Performance Parts Discussion |
Factory EGT sensor w/H&S blocker plates
Has anyone used a factory EGT sensor from the DPF with the H&S blocker plates? If so, what EGTs are you getting and could you provide a pic?
Thanks |
Pretty much everyone deleted does. Mine can get up over 1400 but normally stays below 1000. Sorry no pics
Sent from my SAMSUNG-SGH-I717 using AutoGuide.com App |
If everyone deleted it then, here is another question. My EGR delete blocker plates, one of them was pre-drilled for the EGT sensor. Are people not putting the sensor in there?
He meant that everyone that pretty much everyone that deletes there DPF uses the sensor in the blocker plate/ all the guys run the dpf sensor in there blocker plates to get EGT readings.
how hard is it to install those plates from h&s?
If you delete the EGR , that will give you a built in spot to use a Pyro sensor from your DPF you cant use the EGR one it will give false readings. As to the difficulty I can not say I will do some things but that i left up to the shop. they do them all the time and I would do it once so I said I not going to save an hour or 2 labor to get 50lbs of junk removed since if the mess something up its on them. I should post a pic on how it opens up the passenger side of the engine compartment.
Lance |
