Torq2= Reduced Engine Power - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 11-13-2011, 06:52 AM
Just installed the Torq2 I got off Mystic, did everything properly, had to remove the white clip from the factory peice, made sure both ends "snapped" together tightly, jumped in the truck, turned the ignition, and the first thing that popped up was "Reduced Engine Power Mode"...any suggestions?
I re checked the connections and they are tight, still same issue. Does something have to be reset to get rid of that code?
Old 11-13-2011, 07:05 AM
Just put everything back to stock, and did not get the Reduced engine power code, but my check engine light is on. No codes come up on the system check tho. WTF?
Old 11-13-2011, 07:24 AM
Just get a mini max from H&S , stop pissing around with the cheapo mileage / power adders. Reprogram the Ecu with a mini max and be done with it. Sheesh
Old 11-13-2011, 07:29 AM
Cuz I don't have a grand+ to drop on a programmer right now, or 15k to replace a motor if something goes wrong!
Thanks for the helpful response tho!!
Old 11-13-2011, 07:34 AM
Surrounded by Corn!
That sucks man, I hope you get her fixed. I agree with Matty though. The H&S Mini has been great.
Old 11-13-2011, 10:59 AM
Make sure that on the end you removed the white piece from that your not putting the connector in upside down. That could be my only guess
http://www.dieseltalk.com/support/Torq2Install.pdf
Old 11-13-2011, 01:06 PM
Thanks, that was it!! Feel like a dope, but I never knew someone would make a plug that goes in both ways with one being incorrect!! Brilliant!! That, and I was doing it blindly b/c my big hands and small places do not leave much room for seeing!!
Truck runs great, now, how do I get the damn CEL off?
Old 11-13-2011, 03:53 PM
Might go away on it's own. Or if u got a friend with an OBD II scanner. That might clear it.
Old 11-13-2011, 04:09 PM
Surrounded by Corn!
I believe the CEL will go away after time. Just when you get sick of looking at it and schedule an apt, it will go away. That's how it works.
Old 11-13-2011, 05:17 PM
First 6.7 PS Destroyer
Lol this happened to me at first! Glad you got it figured out! Now go haul *** cel will go away after a few miles or start ups. Let me know if you need anything man.
