Monitoring EGT's? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 08-25-2011, 11:51 PM
Monitoring EGT's?
I have a couple of questions for you guys about EGT's and where to drill.
I see that you have to install a pyro for H&S tuning, but they only give instructions for install if using egr delete kits and dpf off. How do I monitor EGT's if i want to run dpf on tunes?
I read there isn't a pre turbo pyro in a 6.7, so where is spartan reading the egt's or is there a reading?
Lastly has anyone installed a mechanical egt gauge? And where did you put the pyro?
Old 08-26-2011, 04:02 AM
First 6.7 PS Destroyer
I've been wondering the same thing. Someone will help you soon. No mechanical gauges as far as I know, not really a need when the tuner display can do it.
Old 08-26-2011, 05:41 AM
correct me if im wrong, but couldnt you the pyros on the dpf theres at least 2 of them in there, on the H&S display
Old 08-26-2011, 05:42 AM
just had the switch the HS to FACTORY PYRO i think somewhere in the menu
Old 08-26-2011, 05:54 AM
Picking up a pyrometer signal in the DPF would be useless. Could be as much as 1000°F cooler once it gets to the DPF (assuming the DPF is not burning off soot at the moment). The only place for a pyro to go is in front of the turbo.
Old 08-26-2011, 07:10 AM
For the time being, I have an Edge Insight CS watching my temps just after the turbo (pre DOC and DPF) and just after the DPF. Interesting to watch the temps after the DPF during a regen.
Old 08-26-2011, 12:44 PM
That is what I was thinking. Is there room in front of the turbo for a pyro? I haven't really looked real close. Has anyone actually tapped for a pyro near the turbo?
Old 08-26-2011, 07:19 PM
I asked my service advisor about this just after I purchased the truck.
He strongly advised against it while the truck was under warranty.....If any evidence of a pyro being installed was on a truck in for engine related repairs while under warranty, the tech was to call mother Ford regarding what additional testing to perform.
That's where he made mention of using a non-intrusive gauge package such as the Insight unit.
Granted, Ford does not have a pyro right in front of the turbo, but some info is better than none.
Of course, YMMV
Old 08-26-2011, 08:20 PM
That's were he made mention of using a non-intrusive gauge package such as the Insight unit.
Of course, YMMV
Didn't really think about warrantee issues. Really, im not going to tune my truck till at least the 3 year/36000 mile warantee runs out. I just want a EGT gauge for towing, and turbo cooling shutdown reasons.
I like your legal disclaimer, might have to steal that.
Old 08-26-2011, 09:13 PM
Also, the Insight unit keeps me informed of the regen process. I wish Ford would give us some type of indicator or message of entire regen process taking place....not just letting us know it is starting it. I know you can tell by your mpg's falling below normal, but I like to have something more dedicated.
