Any News From Innovative Diesel? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 06-24-2011, 09:46 PM
Info on the sct unit they tune on???
Old 06-24-2011, 10:40 PM
what???? they dont tune on a sct unit, they write tunes with the SCT software tuners can purchase but then you can load the tunes on any of the SCT tuners that allow you to load custom tunes.. i.e. SF3, X3, X2, Live Wire, TSX, etc
nvm just saw this was in the 6.7 section
ur just wanting to know do they have tunes for the 6.7 yet?
Old 06-27-2011, 05:19 PM
First 6.7 PS Destroyer
This is still a good dang question.
Old 06-27-2011, 06:45 PM
Innovative has a 6.7 fuel rail chip called Torq2. I'm waiting on mine to arrive
Old 07-01-2011, 06:35 PM
I wonder how it compares to the mp8 and if it's traceable or not.
Old 07-02-2011, 10:54 AM
It's between the PCM and fuel rail so I'm assuming the PCM is reading proper rail pressure when in turn the rail chip cranks it up. So the PCM wouldn't get any higher then normal readings thus not traceable
Old 07-02-2011, 07:47 PM
AlbertaStroker let us know what you think bout that torq 2 rail pressure "box" when you get it on. Thanks.
Old 07-10-2011, 06:41 PM
Nice, I may get one. I miss the power of my old truck.
Old 07-10-2011, 06:58 PM
Installed the Torq2 the other night. Semi difficult install because the fuel rail connection is below one of the rad hoses/boost tubes on the drivers side ( suggest install while the engine is cold, I had quite the red arm when finished). Also the connections are a very very tight fit. All of the wiring that IDP has fabricated is top notch and the product finish is 10/10.
Once I got the install done and the adjustment knob installed in a nice discrete place I took the truck for a drive. Did a couple WOT runs on a secondary highway at stock setting for a feel and then did the same with the dial cranked to 100% and there is a huge difference. Breaks the tires loose like nothing. As for MPG gains. I'll report back after a tank or two of fuel.
