dpf delete??? - Ford Powerstroke Diesel Forum
6.7 Performance Parts Discussion 6.7 Performance Parts Discussion
Old 12-20-2010, 05:05 PM
dpf delete???
anyone tried to remove... tips, tools needed? looks like getting hangers off is going to be a b....!
Old 12-21-2010, 05:53 AM
I suggest taking the hanger brkts off the frame(from the outside of the frame rail/ a series of 13mm lock nuts) and removing it as a complete assembly with all the sensors,hangers,rubbers and even the uri injector. Unbolt the factory exhaust at the 3 bolt flange if it's going to be reused just ratchet strap it back a inch or 2 and it should stay in the rubber hangers for the tailpipe. It is a two person job to get this unit out as it is much heavier than the 6.4 assembly. It's not much harder than doing a 6.4 other than the weight of the part.
Old 12-21-2010, 05:57 AM
Send a message via MSN to babs2972
Subscribing. I want to do mine on an 05 and was wondering if there were any problems? Any input, good or bad.
Old 12-21-2010, 08:09 AM
I looked at mine when I recieved everything and said WTF! It looked like a lot of work so I had mine put on for $135, which was money well spent.
If you do put it on I would suggest you have someone helping along with an impact wrench.
I posted a picture of the factory system taken off in a previous photo and that thing weighs easily over 100 lbs.
Good luck!
Old 12-21-2010, 06:21 PM
thanks alot for the input... looks like good christmas project!
Old 12-27-2010, 04:52 PM
piece of cake!!!
Installed my pipe over the weekend... props to powerstroker67, your suggestions made this a breeze!!!! Yes that pipe is HEAVY, 2 man job for sure! Thanks again for the input. HS turned up... WOW this thing is bad!
Old 01-02-2011, 11:49 AM
Installed my pipe and tuner from Sean yesterday and his directions and customers service is top quality just like his pipes and EGR block off plates! Thank you
Old 01-02-2011, 11:50 AM
Can I be stupid and ask what a dpf delete is
Old 01-02-2011, 03:20 PM
Diesel Particulate Filter. Another emissions device.
Old 01-05-2011, 04:23 AM
Dude I thought you were not going to tune your truck! lol
When I told you I was going to do mine when it came out you looked at me like I was crazy!
How do you like it? I bet you enjoy they extra 3MPG like me!
