Finally got the NL stage 2 intake and block off plates done today. Installed the egt sensor in the plate needed to work with SCT devices.
Two questions:
1. When setting it up on the livewire does this sound correct? Analog wire firewire. Setting is SCT EGT 9815 (part number that was on my egt box)
2. Is the only way to get this wire through and into my device through the little rubber gasket? It's kind of a PITA to try and get my hands in there let alone push through the FireWire cable( think of it as a usb cable)
Thanks!
Two questions:
Thanks!
