How to add EGT to EGR Delete wth MiniMaxx? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-12-2014, 01:28 PM Thread Starter
Quoted: 3 Post(s)
Lots of EGR threads going at the moment but I still can't find what I'm looking for. I have ordered a MiniMaxx and No Limit EGR delete. I have the vague understanding that the MiniMaxx can use a stock EGT sensor (removed from the DPF?). What I'm looking for is a little more information as to HOW. Near as I can tell, I need to purchase the H&S PCH board (P/N 709403) which acts as the interface between the EGT sensor and the MiniMaxx. Is that the case? I don't need their Universal Pyro kit (P/N 709401) since I can just scavange a sensor from the DPF right?
If I go that route, I imagine I'd have to cut the connector off one of the DPF sensors. I'd kind of like to keep my DPF plug & play ready in case I need to put it back on in the future. In which case, I'm wondering if I shouldn't just order the universal pyro kit instead. Will the H&S pyrometer fit in the No Limit blocking plate?
2012 F-350 Lariat CC SRW 4x4
Leveling kit with 35" Nitto Trail Grapplers
EskimoPie is offline
post #2 of 13 Old 08-12-2014, 02:57 PM
agjake11's Avatar
Feedback Score: 3 reviews
use sensor from DPF and install into plate on manifold. Then plug it into where the sensor that was in the egr piping and youre done.
Not full delete so you can see both the new sensor in the middle and old sensor just below it where you unplug and plug in the dpf egr sensor
13 F250 XLT Premium 4x4 PMF/Icon/H&S/Flo-pro/Frontier
13 Suburban LTZ
agjake11 is offline
post #3 of 13 Old 08-12-2014, 08:04 PM
dont forget to spray them bolt with WD40 and leave over nite, mine were a nightmare to screw them out.
2012 f250 Ultimate Lariat, 6.7 powerstroke
Hunter69 is offline
post #4 of 13 Old 08-12-2014, 10:08 PM Thread Starter
Quoted: 3 Post(s)
Thanks for the tips and especially the picture!
post #5 of 13 Old 08-12-2014, 10:25 PM
Ryan2012F350's Avatar
Garage
Cannot stress enough to prep those bolts to pull, soak em in something to make sure they don't break.
I did mine at 30k and they were close to not coming out. I imagine it would be a nightmare to drill those out.
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #6 of 13 Old 08-12-2014, 10:27 PM
Quoted: 19 Post(s)
Plug and play brutha. No extra anything needed. As said use the sensor from the dpf.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #7 of 13 Old 08-12-2014, 10:36 PM Thread Starter
Quoted: 3 Post(s)
Specifically which bolts? The ones holding the short and long EGT pipes to the cooler?
post #8 of 13 Old 08-12-2014, 10:38 PM
Garage
The ones down on the bottom of the pipe.
IN the pic above it's where the plate with probe is installed, right now you have a pipe attached there.
post #9 of 13 Old 01-29-2016, 09:44 AM
F350KR's Avatar
so the Mini maxx wont read any EGT sensor until you add the one that was in the old down pipe? didnt someone say there is already one installed close to where you have to add the second one?
thanks
F350KR is offline
post #10 of 13 Old 01-29-2016, 03:49 PM
outbacker's Avatar
Quoted: 28 Post(s)
thanks
A Ford factory EGT sensor can be used with the minimax. Just put the EGT sensor in your pre-threaded exhaust manifold plate that comes with the EGR delete kit or block off plates. EGT sensor plugs into where the EGR EGT sensor was previously plugged. Don't use the EGT sensor from the EGR pipe.
2012 F-250 CC, SB, 6.7L Power Stroke.
Pulls a 2014 Keystone Outback 301BQ.
outbacker is offline
