XRT Pro - Ford Powerstroke Diesel Forum
post #1 of 23 Old 08-08-2014, 07:06 PM Thread Starter
Leadfoot205's Avatar
XRT Pro
I have an Xrt Pro 109005 for my 2012. I already unlocked it. I picked up a 4" Flo Pro and a 40" Donaldson. I'm just looking to use the stock power level H&S delete tune. My first question is will my turbo be pressurizing over 25lbs or is it really a stock tune with just the sensors turned off? My second question is, I have an Edge Insight. If I do an egr delete, do I need to add an Edge pyro or will it read a relocated dpf egt sensor. I've read a couple contradicting topics on it. Thanks in advance.
Sent from AutoGuide.com App
Leadfoot205 is offline
post #2 of 23 Old 08-08-2014, 07:12 PM
Quoted: 26 Post(s)
I have almost the same setup on my '13 with a street XRT. If you update the tuner with H&S, the boost should be limited at around 23 psi. If you do the EGR delete, I believe you will need the EGT probe kit as well. I have read that the stock sensor was tried but didn't work.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #3 of 23 Old 08-08-2014, 07:58 PM
HighHP's Avatar
Yah I got the stock sensor in mine right now and no luck. I msgd edge about adding more pids like h&s has but they were completely useless and didn't give a ****. Im quite pissed about their customer support. I'll keep running the CTS cause I have it but I don't know if ill be suggesting it to others to buy anymore. Highest I've seen for boost with my XRT is 24
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #4 of 23 Old 08-10-2014, 03:59 PM
DIGMAR's Avatar
Quoted: 25 Post(s)
Yeah, I called them and asked if the stock probes would work to read EGT's with my delete and got the blanket "these are not designed to be used in that way, so we don't know and can't tell you..." seriously??
2012 F250 Lariat CCSB SRW:
H&S XRT w/ Gearheads tunes, Edge CTS, 5" FLO PRO DP Back w/ Muffler
S&B CAI, EGR Block Off Plates, No Limit CCV
Retro HIDs, ProComp 2.5" Stage3 level/lift, Fox 2.0 IFPs, 295/75/20 Toyo AT IIs
DIGMAR is offline
post #5 of 23 Old 08-10-2014, 05:35 PM Thread Starter
Thanks for the replies. Guess I'll be ordering the Edge sensor too. Is it the same size thread as the factory dpf egt sensor or do I need to order a certain brand for the delete?
post #6 of 23 Old 08-10-2014, 06:14 PM
HighHP's Avatar
Sinisters used to work but everyone running the mini Maxx complained so they switched to the oem style. Currently mine isn't compatible with the edge probe but I'm trying to get ahold of them supposedly they are making a new run of the original style
HighHP is offline
post #7 of 23 Old 08-11-2014, 06:37 PM
Quoted: 26 Post(s)
I emailed them and they offered to switch mine out for the NPT version if I shipped mine back. You may give it a try, if interested.
post #8 of 23 Old 08-11-2014, 06:55 PM Thread Starter
I emailed them earlier and am waiting for a reply. Hopefully they have some left. I also tracked down a guy on a popular auction site that looks to have some older kits. I'm waiting for confirmation on the size.
post #9 of 23 Old 08-11-2014, 09:32 PM
HighHP's Avatar
Let me know if you can get the size confirmed. I haven't heard back from them yet but If they tell me to send my plate back they can screw themselves. How do I run a truck with exhaust blowing all over the engine waiting for their new plate...
HighHP is offline
post #10 of 23 Old 08-11-2014, 09:36 PM
Quoted: 19 Post(s)
the factory port is 1/4 NPT , the aftermarket port is 1/8th NPT , pm your address and ill send you a stainless bushing and plug free of charge.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
