Install MiniMaxx without deleting? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-04-2014, 11:52 AM Thread Starter
Quoted: 4 Post(s)
Pretty sure this is OK, but wanted to double check. I have a full delete setup on the way from No Limit. The MiniMaxx will arrive today but I can't do any of the actual delete until this weekend. I can go ahead and plug in the MiniMaxx, and even do a non-delete tune with the truck still stock right? Then when I do the delete, I just remove the tune, and the re-program it with the delete options selected right?
I'm impatient and don't want to have to just stare at it till Saturday.
2012 F-350 Lariat CC SRW 4x4
Leveling kit with 35" Nitto Trail Grapplers
EskimoPie is offline
post #2 of 4 Old 08-04-2014, 12:27 PM
POWERCHOKER
Dantron's Avatar
Yep that should work...
Dantron is offline
post #3 of 4 Old 08-04-2014, 03:00 PM
ucpa111's Avatar
Quoted: 7 Post(s)
Pretty sure I will be in this boat too. Trying to figure out the delete stuff I want to do….but will likely want to install the MM and see what it does with the truck prior to the delete and make sure the Minimax works correctly.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #4 of 4 Old 08-04-2014, 04:36 PM
I've been running my MM for over a year without deleting. Huge difference and runs great
2012 Super Duty CC SB Lariat 6.7
Line-x Bedliner, 5% Tint, Carli Suspension Lift, 20x10 American Force Wheels "Rebel SS". Toyo M/T's
Dose is offline
