Going to delete - looking for muffler guidance - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-03-2014, 04:50 PM Thread Starter
ucpa111's Avatar
Quoted: 3 Post(s)
As the title states, I am looking to delete. I actually want the truck to look stock (to the casual observer), so I prefer to keep the stock exhaust tips (I know some folks will bristle at that). I am wondering if I should just keep the last section of pipe that connects to the stock tips? Is there a resonator in that section?
I want to use a Donaldson 51" (but can be convince of something else if simpler). I have found the part number. What else should I purchase to make this work? Do I need to custom fabricate hangers? Do I need to do something about flanged ends? Do I need to order hangers or clamps or? I am looking at 4". I guess I prefer stainless but aluminized is probably fine (I guess the donaldson is aluminized, correct?). I am curious if the Flo Pro system with muffler sounds comparable? I see so many options (for example on Rudy's site) that I am confused.
I am curious if anyone has a setup like this and can point me in the right direction for part numbers for what I need or make some suggestions?
Thanks. I searched and found some information, but not anything that listed what I would need to make this system work. Sorry for so many questions...
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #2 of 13 Old 08-03-2014, 05:47 PM
Quoted: 25 Post(s)
You may want to research installing a DPF delete pipe and not a full exhaust. Something like this AFE ATLAS 4" Aluminized Cat / DPF Delete Pipe 11-14 6.7L Powerstroke looks like you would only need to cut in a muffler of your choice. It appears to have the flare on the front end and a flange on the rear. Should be pretty simple if that is all it takes.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #3 of 13 Old 08-03-2014, 06:34 PM
Quoted: 19 Post(s)
let me know if I can help! I can get you anything you need !
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #4 of 13 Old 08-03-2014, 06:41 PM
Quoted: 4 Post(s)
I did exactly what you are talking about. Order a 51" Donaldson muffler and a DPF delete pipe (one that comes in two pieces). Remove the DPF. Install the front piece of the two piece delete pipe (attaches directly to the stock down pipe). The Donaldson slides right on to the end of that piece. Now all that's left is to measure and cut the 2nd piece of the delete pipe to install between the muffler and the factory tailpipe section. You'll need a couple of 4 inch clamps. I didn't have to add any hangers or supports and it's solid.
I did this and it looks completely stock except for the soot on the tailpipe. The sound in the cab is close to stock. The sound outside the truck is louder, but nothing too loud.
2013 F250 6.7 PSD
Crewcab FX4 6.5 ft bed
Factory 18" Michellins 3.55 gears
DPF and EGR delete 51" muffler
Punch it Performance tunes
Deerhunter4 is offline
The Following User Says Thank You to Deerhunter4 For This Useful Post:
Tidestroke6.7 (09-12-2014)
post #5 of 13 Old 08-04-2014, 04:16 PM Thread Starter
ucpa111's Avatar
Quoted: 3 Post(s)
If someone wanted to PM with where to buy, what part numbers, etc I'd be appreciative. Deerhunter, it seems you have exactly the setup. Also, are the tunes you're running superior to H&S canned in your opinion? I am really looking for a good daily driver, better mileage if I'm easy on it, and longevity. I do tow once in a while.
Also, I am trying to decide on block off plates or full delete on the EGR. And what about intercooler pipe? Are people changing those out as well? Thanks!
THIS THING ROCKS!
ucpa111 is offline
post #6 of 13 Old 08-08-2014, 06:13 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
I did delete pipe and cut this muffler in. With stock tips.
Banks 4" Stainless Steel Monster Exhaust Muffler 53800
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
post #7 of 13 Old 08-08-2014, 07:14 PM
Quoted: 25 Post(s)
How loud is it?
post #8 of 13 Old 08-13-2014, 12:41 PM
Redleg's Avatar
Does the Donaldson muffler come with clamps? Just ordered the 40" and forgot about needing a muffler clamp.
2015 F350 Platinum CC SB 6.7 4X4
Redleg is offline
post #9 of 13 Old 08-13-2014, 12:46 PM
Quoted: 4 Post(s)
No. My 51" didn't. You can get the cheap clamps at autozone.
2013 F250 6.7 PSD
post #10 of 13 Old 08-13-2014, 01:17 PM
Quoted: 2 Post(s)
No they don't come with it I just put my 40 on last week. If your doing the 4 inch pipe the clamp p/n is 20400ES they are stainless you need two of them If you just ordered it you should be able to call them and have them add them to your order.
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
