New guy, whats the best setup - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By jcain
  • 1 Post By N2Deep
post #1 of 8 Old 07-30-2014, 08:37 AM Thread Starter
Quoted: 5 Post(s)
Whats the best setup on tuner, exhaust delete, CAI, egr block off. Or any other combo thats safe.
I have a 2012 F350 4x4 SRW, I want more power. But don't wanna hurt my motor or transmission. I had read some post where people had hurt their tranny with using a tuner. I wanna add more power, but not at the cost of hurting the motor
N2Deep is offline
post #2 of 8 Old 07-30-2014, 10:16 AM
Quoted: 2 Post(s)
Then don't tune it or add anything.
blakerugg likes this.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #3 of 8 Old 07-30-2014, 10:57 AM
POWERCHOKER
Dantron's Avatar
Your motor and transmission should be fine. I would go with the H&S Mini Maxx, Flo Pro exhaust, any cold air intake and any EGR block plate kit or full delete kit. That should get you started at least...
Dantron is offline
The Following User Says Thank You to Dantron For This Useful Post:
Bryce18 (07-30-2014)
post #4 of 8 Old 07-30-2014, 12:56 PM Thread Starter
Quoted: 5 Post(s)
I've seen a lot of post for the SCT x4 an mini max tuners. Which one is a better tuner? On exhaust, it would be flo-pro or AFE 5" with no muffler. On intake, S&B or AFE. EGR block off????
And on the tuners, why do you like yours? Pro's/Con's
Okielawnboy likes this.
N2Deep is offline
post #5 of 8 Old 07-30-2014, 04:37 PM
I'm going thru the same dilemma right now on my '12.I have about settled on H&S xrt pro, and got AFE cold air coming. Still need an exhaust and not sure about deleting egr since it looks like the issues w the coolers are over.
2012 F250 CCSB King Ranch 4x4. DPF and EGR delete. XRT Pro. 2.5" Skyjacker lift. 20x9 XD Hoss w/35-12.50-20 Toyo Open Country MT's,AFE Stage 2 intake, Retrax bed cover. Getting there...
Okielawnboy is offline
post #6 of 8 Old 07-30-2014, 04:47 PM
Quoted: 20 Post(s)
I sell both tuners. the sct x4 is the best bang for the buck, coming in cheaper at $749 , where the mini maxx is $1899 , obviously there are discounts on either when purchasing a package. the mini maxx is superior in monitoring and the ability to use mcc which allows custom tuning options. the sct tunes are very good as well the h&s . you can also go with the XRT pro at $1499, I sell those as well. best bet is buying everything at once to get the best savings.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #7 of 8 Old 07-30-2014, 05:00 PM
Well I have found an intake used and a couple of unlocked programmers used locally. Still hunting for exhaust but going to wait a bit to recover. Trying to make this as easy on the wallet as possible.
post #8 of 8 Old 07-30-2014, 05:12 PM
DIGMAR's Avatar
Quoted: 26 Post(s)
If your going with the XRT I'd recommend looking into the Edge Insight CTS as well... makes up for the inability to monitor gauges through the XRT. screen is bigger than the mini as well so its easier to see. Cant go wrong with a Flo-Pro down pipe back with or without muffler (depends on how loud you like it). I just installed my 5" flo pro this weekend and it only took a few hours to do. For the EGR, if your not planning on deleting it all together, your better off at least picking up some block off plates. It'll let you run a probe to monitor your EGTs (have to buy the edge probe though) but more importantly your not filling your EGR with exhaust that's just backing up against the valve (your supposed to disable the valve by unplugging the connection for it when running DPF delete tuning). I picked up an EGR delete kit and just used the manifold block off and had an aluminum plate to cap off the EGR inlet fabricated. you can probably still pick up an old H&S block off set that's floating around.
DIGMAR is offline
