Dura Mileage Engine Module??? - Ford Powerstroke Diesel Forum
post #1 of 19 Old 07-05-2014, 10:16 AM Thread Starter
JAH
I was curious if anyone on here has tried the engine module from Dura Mileage. They claim that since it does not plug into your computer the technicians at the dealership cannot detect anything. It plugs in series with your fuel rail sensor. Any input is much appreciated!!
JAH is offline
post #2 of 19 Old 07-05-2014, 12:09 PM
Quoted: 83 Post(s)
Appears to be only for the DuraMax engine. The claims do not appear to add up if you rear any of the forums. It appears to be a reprogram of the ECU from what I read.
Do you have a link to what you are asking about?
Larry1013 is offline
post #3 of 19 Old 07-05-2014, 02:19 PM Thread Starter
JAH
Link
Best Diesel Chip
Try this. There is a tab for duramax and powerstroke.
JAH is offline
post #4 of 19 Old 07-05-2014, 07:52 PM
Quoted: 2 Post(s)
It is a fuel pressure box, like the IDP Torq 2.2.
It raises your fuel rail pressure beyond the truck manufacturer's specifications.
There has been concern about premature wear on the truck's injectors (with extended use) due to the increased pressure but it hasn't been verified.
Since it doesn't reprogram or modify your truck's computer (ECM) it can be removed and no one will ever know.
I ran the Torq 2.2 and could tell that it added a little extra power. Fuel economy was "minimally" improved. I say this because my mpg's were better than stock but my truck regenerated more, which hurt my mileage.
I believe Dura Mileage offers a Money-Back Gurantee, so you might as well give it a try.
Truckmaniac is offline
post #5 of 19 Old 07-05-2014, 09:51 PM Thread Starter
JAH
I don't want to void my extended warranty, that's the real question? Thanks for the replys.
JAH is offline
post #6 of 19 Old 07-06-2014, 07:17 AM
Quoted: 2 Post(s)
As long as you don't go in for warranty service with it installed, you won't void your warranty.
The device takes less than 10 minutes to install/remove.
Go for it and report back!
post #7 of 19 Old 07-06-2014, 07:25 AM
Quoted: 2 Post(s)
This is essential the same thing as the Dura Mileage:
Area Diesel Power Module Ford 6.7 Powerstroke Power Chip - Little Power Shop
post #8 of 19 Old 07-13-2014, 11:24 AM Thread Starter
JAH
Engine code
I installed the fuel module a few days ago and everything was rocking along good, fuel mileage went up 3 to 4 miles per gallon. Today I get the service engine light and it's throwing out PO170 code which is fuel bank 1 lean. Any ideas?? Should I remove the module??
JAH is offline
post #9 of 19 Old 07-13-2014, 11:53 AM
garyfulton's Avatar
Good lord........
garyfulton is offline
post #10 of 19 Old 07-13-2014, 02:15 PM
Quoted: 2 Post(s)
YES! YES! YES!
