Turbo quetion - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-12-2014, 09:27 AM Thread Starter
Cheap6.7's Avatar
Turbo quetion
So what is worse for a turbo, going 0-30 psi fast or holding at 30 psi for a little bit? Experts help me here. Thanks
Buy American!
Cheap6.7 is offline
post #2 of 6 Old 06-12-2014, 01:35 PM
08powerstroke6.4's Avatar
Quoted: 33 Post(s)
pretty sure 30lb boost is to much for a 6.7 turbo. mine makes 23psi after h&s updates
Chris
2012 f350 crew cab dually lariat
h&s tuner w/dpf delete
5in exhaust w/fte resonator
2008 f250 reg cab short bed
Livewire w/tyrant tunes
Dual exhaust
Already faster than my 6.0 :/
2006 f250 crew cab king ranch
Head studs
Mpd 175/30 inj.
Fass fuel pump w/sump
4in mbrp exhaust
s&b intake
ec-1 coolant w/coolant filter
blue spring upgrade
powermax turbo w/ billet wheel
egr delete
sct livewire ts w/ php tunes
Atlas 40 ficm
08powerstroke6.4 is offline
post #3 of 6 Old 06-12-2014, 02:49 PM Thread Starter
Cheap6.7's Avatar
Well I really ment in general. But thanks for the input.
Buy American!
Cheap6.7 is offline
post #4 of 6 Old 06-12-2014, 06:02 PM
matty21's Avatar
Generally then, Holding pressure , especially that high for extended time is harder on it.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 6 Old 06-12-2014, 06:32 PM
Quoted: 20 Post(s)
honestly getting out of 30+ psi is the worst for it. that "stall" can be hardest on a shaft, which is weak to begin with on the 11-14 6.7 turbo . I don't think acceleration of the turbo rpm is very hard on it. but maintaining 30+ psi is very hard, and getting directly out of the throttle is hard. remember , at 30 psi this turbo is at close to 180,000 rpm ! it, at that boost level , is WAY out of it's map ! they pop relatively easy at stock boost pressure of 22 psi !
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #6 of 6 Old 06-13-2014, 03:24 AM Thread Starter
Cheap6.7's Avatar
Thanks guys.
Buy American!
Cheap6.7 is offline
