Edge CTS Pod Mount - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-02-2014, 08:35 AM Thread Starter
Quoted: 226 Post(s)
Edge CTS Pod Mount
Does anyone have the monitor using Edge's pod mount? I can't figure out how it attaches on my 15. There is a 1/2" gap between the pod and the dashboard. I can take pics.. wondering if Ford changed the design at all so the 11-14 doesn't fit.
15 6.7 F350 CCSB 4x4 Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2, Dieselsite fuel filter, DeeZee tailgate assist, Hellwig Rear Sway bar, Bilstein 5100s
**Support the Online Vendors!!! Want your best price, buy from Scott Pratt!! Get your truck in 3-4 weeks, order to delivered!!
blwnsmoke is offline
post #2 of 7 Old 06-04-2014, 05:53 PM
post up a pic, when I asked Edge they said they only fit trucks up to 12 but couldn't tell me why so I decided against one for my 14, still curious what doesn't fit though.
14 CCLB, stock
kampy is offline
post #3 of 7 Old 06-04-2014, 06:02 PM Thread Starter
Quoted: 226 Post(s)
I ended up returning the pod and CTS back. Only had till 6/5 to return it for my money back. The CTS will not work on the 15s yet and Edge's reply was maybe sometime this summer as they have other projects they are working on.
The pod stuck out about 1/2 forward of the dash. It was the curve on the right side of the pod hitting the dash before the rest did. If I took a saw to it, I could have possibly got it to fit but for $40, I wasn't going to do that.
So basically think of the pod as sitting flush up against the dash, then pull it away evenly on both sides 1/2" and that's where I was at.
Thanks for the reply though.
post #4 of 7 Old 06-04-2014, 07:39 PM
Quoted: 25 Post(s)
I purchased a H&S dash pod to fit the 13-14s and that has the standard 2-1/16" hole in it. I then cut out the face to allow the cable through in the right spot and glued the CTS base to it. It was a little more money, but turned out pretty nice.
I also had purchased the Edge 2-1/16" adapter and that didn't work out real well.
When I get a chance, I will pass along a photo.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #5 of 7 Old 06-05-2014, 05:27 PM
Good info Sterling
14 CCLB, stock
kampy is offline
post #6 of 7 Old 06-05-2014, 05:55 PM
Quoted: 25 Post(s)
As promised.
post #7 of 7 Old 06-06-2014, 05:58 PM
That looks great, too bad they want $100 for $1 worth of plastic. I guess you pay to play.
14 CCLB, stock
kampy is offline
