EGR Delete? - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 51 Old 05-29-2014, 12:13 AM Thread Starter
POWERCHOKER
Dantron's Avatar
EGR Delete?
I have the EGR block-off plates installed right now, but I'm debating whether I should do the full delete. I went with the block-off plates so that I could return to stock easier if I needed to get warranty work done. I'm beginning to realize that a catastrophic failure will likely result in a denied warranty claim if an investigation is conducted.
What are the benefits of the full delete vs. the block-off plates?
What kind of delete kits are available and what are the differences between them?
What type of warranty repairs would require me to reinstall the EGR, the DPF, and return to stock tune for nearly guaranteed coverage?
Dantron is offline
post #2 of 51 Old 05-29-2014, 05:39 AM
99powerstroke62's Avatar
Quoted: 56 Post(s)
I've got the sinister kit.
I was back and forth between full delete and block off plates.
I mostly did it because it cleans up the engine bay.
Plus, you can see the turbo hidden in the valley
"Stroker 8" and J_Alvarenga like this.
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #3 of 51 Old 05-29-2014, 06:53 AM
john111987's Avatar
If anyone is debating on whether or not to do block off plates or a full egr delete, I would highly recommend doing the full delete. This past weekend I installed the full delete on my 2011 with 56k miles. Before the delete I just had the block off plates which I installed at roughly 15k miles, along with h&s race tuner and a 5" downpipe back exhaust. So I ran the block off plates for roughly 40k mi. While doing the full delete this weekend I noticed a large amount of black debris/soot(looked like black paint chips) in the hard coolant line that comes up between the egr cooler and intake manifold. I believe that at some point when running just the block off plates that the egr cooler got too hot and blew causing soot to get into the coolant. I will be installing a coolant filter ASAP.
john111987 is offline
post #4 of 51 Old 05-29-2014, 06:59 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
On a side note, does leaving the cover on your air box equal better throttle response? I have seen mixed reviews on this the Lid on, Lid off debate?
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #5 of 51 Old 05-29-2014, 11:55 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Do you ever worry about having to return to stock? I appreciate the input.
Dantron is offline
post #6 of 51 Old 05-29-2014, 11:56 AM Thread Starter
POWERCHOKER
Dantron's Avatar
That's good advice. Thanks!
Dantron is offline
post #7 of 51 Old 05-29-2014, 11:57 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Good question. I'm interested in this as well.
Dantron is offline
post #8 of 51 Old 05-29-2014, 06:20 PM
1stnlast59's Avatar
U would think that the egr cooler would actually stay cooler since there's no exhaust going through it. Stay same temp as engine.
Sent from somewhere in BFE
1stnlast59 is offline
post #9 of 51 Old 05-29-2014, 06:47 PM
john111987's Avatar
Ya I would think so too, just not sure what else could have caused me to have that debris build-up in the hard coolant line. Does anyone have any theories as to what would cause this? Maybe debis from the casting of the block?
post #10 of 51 Old 05-29-2014, 07:27 PM
Quoted: 56 Post(s)
Never, I'm at 146k. All work done is by me.
Tyler
