Pyro temps - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-26-2014, 10:40 AM Thread Starter
Br9
Br9's Avatar
Pyro temps
I just installed my H&s and 5in flo pro. My H&s says my pyro temps are around 2200 is this a correct number. Also where is it reading from. Thanks in advance.
2013 F-250 tuxedo black
Br9 is offline
post #2 of 8 Old 05-26-2014, 10:47 AM
Long Member
TMAG6.0's Avatar
did you also delete the EGR?
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #3 of 8 Old 05-26-2014, 12:39 PM
POWERCHOKER
Dantron's Avatar
That can't be right. I've seen a few other guys have false readings like that. I can't remember what the fix was off the top of my head though. It should be around 300 at idle and no more than 1500 at wide open throttle. Did you install a pyrometer with the EGR block plates?
Dantron is offline
post #4 of 8 Old 05-26-2014, 01:03 PM Thread Starter
Br9
Br9's Avatar
No I haven't yet.
Br9 is offline
post #5 of 8 Old 05-26-2014, 01:31 PM
Senderofan's Avatar
Originally Posted by Br9 View Post
No I haven't yet.
Not sure where that reading is coming from. The H&S uses a temp. probe from the DPF/SCT unit and installs in a bung on an EGR exhaust gas delete plate. If you use the wrong temp probe...ie the one from the EGR...you'll get crazy high temp readings.
2200 degree readings and your turbo would be melting...something isn't right. I'm thinking you need to install the appropriate probe into the delete plate.
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #6 of 8 Old 05-26-2014, 02:05 PM Thread Starter
Br9
Br9's Avatar
So the pyro temp1 # comes from a probe in the egr delete plate. Which I haven't done an egr delete. So this temp I'm getting is coming from something else that probably doesn't even matter.
Br9 is offline
post #7 of 8 Old 05-26-2014, 04:38 PM
Senderofan's Avatar
Correct. But you will probably run in to troubles with the tuner de-fueling the engine if you are running performance tunes. H&S designed a set of safety parameters that will cut fuel to the engine if violated. I ran into this when I used the pyro probe from the EGR unit. Got really weird, and very high, egt readings. The tuner would alarm and then de-fuel. I'm not sure how much adjustment range H&S gives you...or if you can disable the de-fuel function for high egt's.
Just some of the features you should be aware of. Also.....some of the mistakes that people have made in the recent past...whom shall remain nameless .
post #8 of 8 Old 05-26-2014, 05:35 PM
The easiest way to get a good pyro reading is the h&s egt kit. It just replaces the egr inlet pipe with 2 blocker plates. One with a bung for the pyro that goes on the cyl head. Easy 10 min install and your egr is blocked. You can also use one of your oem pyros and plug it up to the egr temp wire that's not being used. Go to the user options on your mini maxx and select pyro source. Then select factory. You'll get some crazy readings if it's not set to the right one.
2011 f250 ECSB 4x4
6.7l 3.31ELD
MiniMaxx Race Tuner w/Gearhead Tunes
4in Exhaust with AFE Muffler
2004 F250 RCLB 4x4
6.0 3.73LS ZF6
4in No Muffler
Coolant Filter
EGR in the scrap pile.
Derek T444E is offline
