advice on install - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-22-2014, 03:19 AM Thread Starter
raptorgabe's Avatar
advice on install
im gonna be installing a full exhaust on my 6.7 and a sinister egr delete kit ! do u guys have any pointers that will make it easier
raptorgabe is offline
post #2 of 11 Old 05-22-2014, 05:54 AM
matty21's Avatar
soak the exhaust bolts with penetrating oil. use a ratchet strap to pull the exhaust apart. have a person or jack to help. the DPF is stupid heavy.
egr delete is so simple, just follow the instructions.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 11 Old 05-22-2014, 06:25 AM Thread Starter
raptorgabe's Avatar
Cool how long would u guess on the exhaust ? I'm pretty machanicly inclined so
post #4 of 11 Old 05-22-2014, 06:52 AM
matty21's Avatar
when i did mine i did the full deleted exhaust (4"), AFE air box H&S tuner and the erg delete and it took about 3.5 hours by myself, and a few empty cans an smoke breaks lol
just the exhaust maybe an hour. if you pre soak all the bolts if they are badly rusted. and have a good ratchet strap or come along. it also helps if you jack up the back of the truck from the hitch . it stretches the suspension out and gives you more room too wiggle the rear piece that bends up and over the axle.
First thing i did was soak all the exhaust bolts, then since the initial download of the tuner takes a while i started that , while that was doing its thing, i removed the stock air box and erg, then put the new air box on then started the exhaust.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #5 of 11 Old 05-22-2014, 07:22 AM Thread Starter
raptorgabe's Avatar
So did u have to drain all the coolant like it says
post #6 of 11 Old 05-22-2014, 07:27 AM
matty21's Avatar
not all. just until its below the erg cooler level.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #7 of 11 Old 05-22-2014, 08:29 AM Thread Starter
raptorgabe's Avatar
Awesome cool !! I only have 20 k on em do shouldn't be to
Hard to get em loose and off
post #8 of 11 Old 05-22-2014, 05:55 PM Thread Starter
raptorgabe's Avatar
im gettin the exhuast tomorrow so i pulled it off just now what is everyone doing with the senors ? coving them and taping them up or unplugging them all ?
post #9 of 11 Old 05-23-2014, 03:28 PM
Senderofan's Avatar
I'd still recommend soaking them down first...as Matty recommended. The exhaust side was about an hour. Depending on your size and availability of friends....you can do it yourself...I did mine alone...not too heavy...but I'm an ancient, has been, power lifter.
Follow Matty's advice and you'll have No problems. He was one of the early ones to go through all these mods....he knows his stuff. He helped me a tremendous amount.
Good Luck,
Wayne
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
The Following User Says Thank You to Senderofan For This Useful Post:
matty21 (05-23-2014)
post #10 of 11 Old 05-23-2014, 03:40 PM
matty21's Avatar
Unplug them , keep the sensors in the stock exhaust, then You can just leave them , or tie them up in the frame. I you plan to go back to stock ever . Just cover the ends to prevent mud from building up inside the connectors. Two ways a ziplock bag and tape it up or just tape it up. Me, I just let them be and it's been several years no issues so pick your own way. Whatever makes you feel good.
Yet to be delivered
AFE stage 2 intake
matty21 is offline
