2013 King Ranch 6.7 Tuners - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-07-2014, 10:00 PM Thread Starter
Just bought a new 2013 was going to wait till I get about 50,000 miles on it before doing any tuners. Was wandering does anyone have any recommendations on ones that would increase fuel mileage and power without voiding warranty. I had a 2002 7.3 and was able to get 18 mpg with a 4 inch lift and 35's with a super turner on tow safe and after market air raid box and filter. Also is there common problems out there with the 6.7 that I should watch out for. Like the 7.3 glow plug relays or the valve cover plug wiring harness problems.
L Bird is offline
post #2 of 6 Old 05-08-2014, 06:01 AM
matty21's Avatar
Do a little reading on here. the answers are all right in front of you.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 6 Old 05-08-2014, 11:44 AM
Quoted: 2 Post(s)
Here's a link to the Innovative Diesel Torq 2.2:
http://www.innovativediesel.com/home-page-products/innovative-diesel-torq2-1-fuel-module-ford-6-7l.html
This and other such "Fuel Pressure Boxes" are the only devices that don't leave a tattle-tail on your truck's engine and transmission control modules. While they will increase power, they typically don't help with fuel economy (Don't believe everything your read), since your truck may regenerate more frequently, using more fuel.
Using a tuner and deleting the DPF will give you a good bump in power, but may or may not increase your fuel economy. On my "deleted" 2013 Platinum, my mileage is sometimes better than "stock" and sometimes the same as "stock". Tuning/Deleting and fuel mileage increases seem to be better on the 2011-2012 trucks than the 2013-2014 models.
While I'd hoped for much better fuel economy, I deleted (DPF & EGR) because I wanted a little more power and to preserve the life of my engine:
...No DPF yield slightly better fuel economy (at times)
...No DPF means I don't have to buy DEF
...No DPF means I don't run the risk of fuel contaminating my oil during regeneration
...No EGR means that I'm not pumping black soot & tar back into my intake
...No EGR means that my oil stays cleaner, longer
Truckmaniac is offline
post #4 of 6 Old 05-08-2014, 02:21 PM
BigGreen06's Avatar
Quoted: 112 Post(s)
To the OP, most diesel performance sites will list the tuners available by year. Check the problems forum for known issues with the '13s and '14s.
Off the top of my head two of the more annoying problems are the ticking that you get after or around your first oil change. Sometimes it goes away after 500 miles, sometimes it stays with you. It is a problem that Ford is aware of, and they dont plan on fixing it, it doesn't cause any harm to your engine its just really annoying. The fix is to change to Valvoline Premium Blue 5W-40 or Shell Rotella 5W-40(or so I've heard).
Second problem is a known issue with a TSB and fix for the trucks with the My Ford Touch Nav system. The Nav at times will show you off course it is pretty annoying, but the fix is covered under warranty, if it occurs take your truck in for the update.
Work Truck: 2010 F350 KR Oxford
Ford F250 CrewCab SWB 4X4 XLT. Sold
4" MBRP 409 SS Turbo-Back w/ Cat & Muff Delete
SCT Livewire w/ Looney Tunes, Courtesy of Vivian
AirDog 100 from Pure Flow Industries
Accufab Elbow
AFE Stage II W/ PG7 Sold!
Revtek 2.5" Level Kit
Nitto TG From Discount Tire
Smkd LED 3rd Brake & Smkd Mirror Lenses From Stealth Auto
LineX in the Bed
HID Highs/Lows 6000K.
Front & Rear Strobes & Front Dual Talon LED Dash Light, All Whelen;
BigGreen06 is offline
post #5 of 6 Old 05-08-2014, 06:13 PM Thread Starter
Truckmaniac and Big green thanks for the replies DPF and EGR all new to me as the 7.3 had none of these things. But from everything I read so far the 6.7 seem to be way better motor then the 6.0 and 6.4 but only time will tell thanks again.
L Bird is offline
post #6 of 6 Old 05-11-2014, 07:37 PM
VT19's Avatar
Quoted: 52 Post(s)
just go on and delete it all and throw a tuner on that beast. your gonna do it before the warranty is up anyway,,,, none has that much discipline, me included
2016 F250 Platinum FX4 (10/02/15)
SCT X4 tuner
Full EGR Delete
Flo Pro full 5'' exhaust / no muffler 6'' tip
3'5 ready lift W/ Toyo AT 2 extremes on factory Platinum wheels
Full exterior LED conversion from Retrosolutions
LED running board lights (added)
SOLD
13 F250 Lariat crew FX4
H&S MiniMaxx Race Tuner
5" FloPro race exhaust w/ muffler
S&B CAI
4" reddy lift
20x10 Fuel Cranks
Toyo M/Ts
N-Fab Steps
70 gallon fuel cell
Carhart seat covers
VT19 is offline
