sinister egr delete - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-01-2014, 05:09 PM Thread Starter
sinister egr delete
Just got done with egr delete, thought some of you would be happy to know that the kit now has the block off plate with the bung for factory sensor. Other than breaking off one of the bolts on the pipe that connects to the manifold I had to get two radiator hose caps because the blue hose was not long enough without being kinked off
Whitehot67 is offline
The Following User Says Thank You to Whitehot67 For This Useful Post:
Tidestroke6.7 (05-02-2014)
post #2 of 7 Old 05-02-2014, 07:30 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Must be a routing issue mine worked ok just had to tuck it behind the fan shroud alil the H&S kit just uses caps so im sure ull be fine just keep an eye on them cuz the caps stress crack under long term pressure and start to leak
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 7 Old 05-02-2014, 09:43 PM
Quoted: 20 Post(s)
yeah the no limit kit also includes a routing hose instead of caps for the same reason. i ahve the h&s kit on my truck because i didnt have the kit done when the time came , but the caps show cracking so i will swap mine over soon.
SCT X4 Off-Road Sale ! $749 for 6.4 or 6.7 up to 2015
Authorized Distributor For :
H&S Motorsports
BMF Wheels
Icon Suspension
No Limit Fabrication
Click Banner Below for All Things No Limit Fab.
800-581-8986
bigrpowr is offline
post #4 of 7 Old 05-02-2014, 09:46 PM
Carli'd6.7's Avatar
Just run on over to your local parts house and grab 4 FT of 5/8th heater core bypass hose and two worm clamps if your dont trust the OEM spring clamps and your golden its kind of funny that SPE sells replacement caps for the delete when you could just sell some hose for twice what its worth plus shipping
post #5 of 7 Old 05-04-2014, 06:24 AM
psdcasper's Avatar
Is everyone who has done the EGR cooler delete happy they did? Guess I need to do that next.
2015 F-350 CCLB Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, Fully Loaded.
2014 VW Passat TDI (DIRTY DIESEL
)42mpg on the highway
(Wife's Ride).
2011 F-350 CCSB 6.7L, Loaded, Lariat Ultimate, FX4 Off Road Pkg, Reese 5th/Goose Hitch, White on Black. (43K as of 4/14) H&S Mini Maxx, Flo Pro delete pipe, Magna Flow Muffler and Sinister EGR Delete . Sold 2/15
psdcasper is offline
post #6 of 7 Old 05-04-2014, 06:52 AM
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
If everyone's engines could talk that was egr deleted they would tell you they are happy
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #7 of 7 Old 05-05-2014, 04:05 PM Thread Starter
Make sure to soak the two nuts on the exhaust manifold over a couple hours, I did it just 2 hours before and ended up twisting a bolt off, got lucky and was able to weld a nut on the remaining stud to get it out
