h&s question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-18-2014, 08:45 AM Thread Starter
h&s question
I have a 13 f250 platinum w/14k miles, not impressed with power ( on performance setting) from a stand still if i just mash the pedal sometimes itll spin shortly sometimes it wont. (stock wheels/tires)
I have the sb intake and the hs race tuner on it.
How much of a difference will it make after i install my delete exhaust?
do i select dpf off now currently while i wait from my exhaust to arrive?
turbotony4 is offline
post #2 of 8 Old 04-18-2014, 11:54 AM
Don't select DPF delete until you actually delete. Also, unless you want to trash your motor, you also should delete your EGR or at the very least block it off. I favor the complete delete option. But DO NOT simply unplug the 2 orange plugs that are on the EGR as this is going to cause issues for you down the road. (there is nothing that says the EGR butterfly valve will remain shut and you could blow the seals in your motor)
I have all of the same things for my '11. They came this week, I just know after months of research and stuff what to do and what not to do. Plus if you do an EGR delete, you can put a pyro right in the exhaust manifold and more accurately measure your EGTs
2011 F-250 Lariat Crew Cab Short Box
6.7L Powerstroke, 3.55 ELD, Clearance Lights, Chrome Package, Upfitters, HD Alternator, Line-X,
6" Chrome Side Steps, RETRAX Tonneau Cover
Just started my mod process:
H&S Mini Maxx Race Tuner
S & B Cold Air Intake
H & S EGR Delete Kit
4" Flo-Pro Stainless Steel Downpipe back exhaust
DesignEngineer is offline
post #3 of 8 Old 04-18-2014, 01:14 PM
Long Member
TMAG6.0's Avatar
As I understand it there is something called Torque Management and Traction Control, those may not be the correct terms but they will limit wheel spin non the less. Even with the DPF deleted you will only get a short spin on the rear tires.
My "seat of the pants" dyno noticed some gains with the DPF removed. But it could just be WooHoo gains 'cuz it sounds so damn cool.... The difference in HP isnt that much
As said above dont select DPF removed until its really removed from the truck.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #4 of 8 Old 04-18-2014, 03:20 PM
I have been driving around with my egr unplugged for the last 2 months and about 750 miles.
Can just unplugging led to this much trouble. Also how could it blow seals? Just asking cause I only followed the HS instructions.
2013 Lariat F250 CCSB 6.7, 4X4, 3.31 locking rear, 50 Gal Titan Tank, 275/70r18 Duratrac Tires, Edge Insight CTS, Bilstien 5100's all around, Dieselsite fuel/water separators. To Come: Race HS XRT Pro
and a hollowed/straight piped DPF/SCR from a donor vehicle
wb880 is offline
post #5 of 8 Old 04-19-2014, 05:03 AM
Long Member
TMAG6.0's Avatar
Would like to know this as well, I did the same thing. I bought the full delete kit but was waiting till warrinty expired to put it on....Save me some time returning to stock.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
post #6 of 8 Old 04-19-2014, 08:13 PM
VT19's Avatar
Quoted: 52 Post(s)
1 VERY reputable programmer manufacturer and 1 VERY reputable diesel performance shop have both told me DONT do the EGR delete until the truck is out of warranty. They BOTH said definitely delete as soon as you can but just wait till out of warranty so you don't have to go through the PITA process of putting everything back to stock, it aint worth it
VT19 is offline
post #7 of 8 Old 04-19-2014, 10:34 PM
Quoted: 48 Post(s)
I know a guy who's been driving around for the past two years and 75k miles like that. You're not going to blow any seals or hurt anything.
drunk on diesel is offline
post #8 of 8 Old 04-20-2014, 12:18 PM
Right?! I know tons of peeps rolling this way, no issues!
jayz is offline
