2013 f350 h&s tuner install - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-01-2014, 04:31 PM Thread Starter
reconscout79's Avatar
This is my H&S tuner install, I couldn't find a thread on this so I figured I'd post one so here it goes. The reason I was looking for a thread was I wanted to see how people routed the wires. Now I see why I didn't find a thread on this is that it is pretty easy to install. So this is a 2013 f350 cb/lb 4x4 the only thing in the instructions that wasn't explained I thought was the install instruction so when it says initiating connection turn on the key and select your model and settings. Otherwise 2013 f350 has a white and blue wire in the loose bunch of wire behind the parking brake pedal that is an acc wire so it turns on with the key(connect power wire there using a red double side connector. Plug it into the box that has the key/batt switch and switch to key.
reconscout79 is offline
post #2 of 6 Old 03-01-2014, 04:36 PM Thread Starter
White blue stripe wire.
post #3 of 6 Old 03-01-2014, 04:42 PM Thread Starter
Ran power box for tuner under the dash, the under dash just pull from the bottom of the panel it's just pull pins same with the side panels. Route the hdmi wire down the side of driver side panel and over the relay box for upfitters and plug to the power box.
post #4 of 6 Old 03-01-2014, 04:46 PM Thread Starter
Power box, under the dash
post #5 of 6 Old 03-01-2014, 04:48 PM Thread Starter
Hdmi wire down driver side panel
post #6 of 6 Old 03-01-2014, 04:53 PM Thread Starter
Used window mount, finished product use zip ties to hold wires together didn't use dbl stick tape just in case, later on I want to move it.
