6.7 Coolant Filter - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 02-23-2014, 10:32 AM Thread Starter
Long Member
TMAG6.0's Avatar
6.7 Coolant Filter
I had one of these on my 6.0. From what I understand it was necessary because sand was used in the engine block casting process and left overs found their way into the coolant slowly wearing out parts. Does anyone see a need for this on the 6.7?? Are our blocks cast in the same manner?
More Info:
Diesel Power Article
DieselSite Coolant Filter
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #2 of 11 Old 02-26-2014, 10:11 AM
I have been considering this but it is not cheap and would like to know how necessary it is too.
2012 6.7L King Ranch Bronze Metallic
Traded up from 2003 Avalanche 5.3L
CW2 US Army
Currently: Watercraft Engineer
Previously: Prime Power, Recruiter, Infantry
Prime Power is offline
post #3 of 11 Old 02-26-2014, 06:37 PM Thread Starter
Long Member
TMAG6.0's Avatar
The one on my last truck was a by-pass filter as well and had very little flow. With these long hoses and low velocity most solids will probably drop out before ever reaching the filters.
Someone needs to try it for a while and cut the filter open.... awww come on!!!
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
post #4 of 11 Old 02-26-2014, 09:33 PM Thread Starter
Long Member
TMAG6.0's Avatar
The passages were very tight in the old 6.0 oil cooler. This sand and debris would get caught reducing the coolers efficiency and causing trouble downstream with low coolant flow. Our coolers look very much like the old 6.0 cooler......Food for thought.
6.0 oil cooler
6.7 Oil Cooler
6.7 Trans Oil Cooler
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
post #5 of 11 Old 02-26-2014, 11:36 PM
HighHP's Avatar
But our coolers are able to be changed in 5 minutes vs the hours for a 6.0 cooler. The biggest problem with the 6.0 coolers plugging was that the lack of coolant leaving the plugged cooler starved the EGR cooler causing it to overheat and burst.
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #6 of 11 Old 02-27-2014, 01:02 AM Thread Starter
Long Member
TMAG6.0's Avatar
So tru I remember it well.
Looking at the 6.7 drawings, the outlets for all heat exchangers on the secondary cooling system return to the degas bottle. The engine oil cooler, which is on the primary system, returns to the bottom radiator hose.
We should not see the same issues where one plugged exchanger can starve the next in line.
"Stroker 8" likes this.
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
Click
TMAG6.0 is offline
post #7 of 11 Old 02-28-2014, 03:02 AM
TampaSteve's Avatar
Feedback Score: 3 reviews
The secondary system has no parts in in that are cast, so no casting debris. Very clean system. The primary still needs one. I believe that diesel site is redoing there kit fort his reason.
2012 F-250 6.7 CCSB
Spartan war hammer, wicked wheel II, S&B intake, 4" flow pro w/dual mufflers, rigid dually's, IPad in dash, JL stealth box under rear seat, Hertz HSK 165 front and rear, JL 450/4, 500/1, line x, roll x tonneau, Titan Tank, and coming soon 6" lift, American force 22x11 Recon SS wrapped in 37's.
TampaSteve is offline
post #8 of 11 Old 04-26-2015, 02:11 PM
I just installed the new kit last week. It is just the primary, fairly nice kit but pricey. I don't drive the truck much unless it is pulling the fifth wheel so it will be a while before I change the first filter. I will cut it open then. Easy install, I let my 13 year old son take the lead on it. This is one of those things that I won't know if it worked, I would only know if it doesn't. Next will be the fuel/water separator from diesel site. Maybe later this year.
CW2 US Army
post #9 of 11 Old 04-26-2015, 04:48 PM
taskforcefreddy's Avatar
Wasn't another issue with our 6.0's clogging up was the coolant itself? The 6.7's use a different coolant and I'm hoping it doesn't have the same gelling problems as the old ford gold coolant did.
taskforcefreddy is offline
post #10 of 11 Old 04-29-2015, 07:42 AM
Merlin2012's Avatar
Quoted: 21 Post(s)
I asked this same question in the general section. you can take a look. I'm do for a coolant flush in 3K so was thinking of adding the one from DieselSite.
http://www.powerstroke.org/forum/gen...r-coolant.html
12 F250 Lariat 4" MBRP exhaust with 4" Down Pipe, Flo Pro Detele Pipe, SCT Tuner PIP tunes, AFE HD intake, No Limit Block Off Plates & CCV, LifeTime LED's, HuskyLiner Mats
Merlin2012 is offline
