Remove Spring Leafs? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 02-03-2014, 07:30 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Would it be okay to remove a single leaf from rear spring assembly?
.......If so, which leaf would be best (safest) to remove?
I'm trying to lower the rear end of my truck between 0.5" <---> 1.0"
Dantron is offline
post #2 of 12 Old 02-03-2014, 08:45 AM
Skyd Ram's Avatar
Quoted: 131 Post(s)
Since these trucks (assuming that you have an F250) only have 2 main leafs plus a lower overload I would not suggest removing any leafs. You could however get a 1" block to replace the 2" block.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is online now
post #3 of 12 Old 02-03-2014, 09:02 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Good to know! I'll be leaving the leaf springs alone. I have a 6 inch lift so I would need to get a block thats an inch shorter than the current one.
Dantron is offline
post #4 of 12 Old 02-03-2014, 09:07 AM
Icon offers a 5" block. I have one with my mini pack
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #5 of 12 Old 02-03-2014, 09:34 AM Thread Starter
POWERCHOKER
Dantron's Avatar
I wish there was another way to slightly rake my truck upward. I'm afraid a full inch might be too much. The truck sits basically level, but at times it looks slightly downward raked. Also, when the tailgate is down, it's definitely not flat or level (that may have something to do with the platinum thing on the back of the tailgate). I need to use a leveling tool to see if it's not my imagination. It might be the way the truck is designed in regards to the overall shape of the body.
ID:	237450   Click image for larger version
Dantron is offline
post #6 of 12 Old 02-03-2014, 10:41 AM
Long Member
TMAG6.0's Avatar
Your truck looks great to me bro. If you do go with different blocks I may take the old ones off your hands. Local pick-up!!
2014 6.7 CCSB FX4
Edge CTS
6" RCX Lift
H&S Turbo Kit
DieselSite Filters
S&B Intake - Dry
No Limit EGR Delete
4" Flo-Pro / Donaldson
H&S Tunes via XRT Pro
Bilstein 5160s Front 5125s Rear
60gal RDS Auxiliary Fuel Tank/Toolbox
Click
to save a childs life.
TMAG6.0 is offline
post #7 of 12 Old 02-03-2014, 11:26 AM Thread Starter
POWERCHOKER
Dantron's Avatar
I'm going to wait it out a bit before I do anything drastic. After I install the fender flares, put on some rear traction bars, and get a toolbox in the bed, I may look at it again and come to the conclusion that it sits fine. Meanwhile, I'm going to find my leveling tool and see if the thing is slightly raked forward.
Dantron is offline
post #8 of 12 Old 02-03-2014, 06:03 PM
I think it would look bad to drop the rear down at all. It will have the look that lifted Chevys have driving down the road. Almost like they sit when they pee if you know what I mean. Have you put a tape to it? That would be the most accurate way, just measure from the ground to the middle of the wheel well. The DS should sit a hair lower if your full of fuel too.
I'll measure mine in the morning to give you something to compare against.
Brett
post #9 of 12 Old 02-03-2014, 08:04 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Brett
Haha...That's a pretty good analogy
Yeah I measured when the lift was first put on and it was definitely even. The truck looks level 90% of the time and I'm pretty sure the other 10% is due to the uneven ground that it happens to be sitting on. That's why I was interested in just removing a single leaf spring because they're only like 0.5" thick. I'm turned off easily by the factory raked look. I know once I have a load in the back I'd regret it if I did anything to the leveling of the truck. When I get a filled up toolbox in the bed the truck ought to sit just how I like it probably 100% of the time. I think this case is solved. I'm just going to leave it alone.
rustyshakelford likes this.
Dantron is offline
post #10 of 12 Old 02-04-2014, 07:18 AM
It's the difference in fender gaps to the body line! The front fender is cut an inch higher then the rear! Look up PMF suspensions...they've blocks in all sizes in half inch increments
jayz is offline
