Problem removing sensors from DPF - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Carli'd6.7
post #1 of 8 Old 02-01-2014, 02:37 PM Thread Starter
Quoted: 2 Post(s)
I'm planning to delete my DPF tomorrow.
I've deleted a half dozen 6.4 trucks and on two occasions, had sensors that had been over-torqued from the factory, resulting in VERY difficult removal and stripping the threads on the sensor.
Have any of you who've deleted your 6.7 DPF experienced trouble removing the sensors?
Do you recommend zip-tying the sensors up to the bottom of the truck/frame or can the sensors be left in the DPF (won't have to worry about stripping the sensor threads) and easily unplugged from the wiring harness?
Truckmaniac is offline
post #2 of 8 Old 02-01-2014, 05:02 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
I just left all my sensors in the exhaust and just unplugged em and drop the exhaust out all in one piece. The hardest part for me was putting the new exhaust in my flow pro box was dropped or something cuz a couple of the pipes didn't slide together very nicely I had to grind and sawzall some stuff. If you damage a sensor and for some reason need one just send me a pic and ill mail ya one of mines.
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #3 of 8 Old 02-01-2014, 05:54 PM Thread Starter
Quoted: 2 Post(s)
I'm assuming that the sensor harnesses connect to a main harness running along the frame (haven't actually looked yet). Is this correct?
If this is correct, are the connectors visible / accessible or are they wrapped with tape or inside a plastic conduit.
What did you do with the DEF dosing module (injector)? My AFE delete pipe came with a plate welded on it to secure the DEF module.
post #4 of 8 Old 02-01-2014, 07:24 PM
Carli'd6.7's Avatar
yes all harness plugs are very easily reached there are two module boxes that I took out not sure what they do , I removed and unplugged all my DEF tank stuff, lines, tank etc. and took the tank shroud out cuz I hated the way it looks. With the H&S tuner you can remove and unplug pretty much everything under the truck haha there was even a sensor on my CCV hose have no idea what it was ,unplugged it, deleted it and still no light haha
Ryan2012F350 likes this.
post #5 of 8 Old 02-02-2014, 04:26 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
If your looking to get rid of the stock exhaust sensors, PM me for my name and address.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #6 of 8 Old 02-02-2014, 04:43 AM
Carli'd6.7's Avatar
Im not looking to but im always willing to help out my stock exhaust is just sitting in my garage and it will most likely never find its way back on the truck sooooo
post #7 of 8 Old 02-02-2014, 04:00 PM
PSDJohn's Avatar
I just left mine in and unplugged them. Plus if you needed them out its alot easier to take them out when its off the truck.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #8 of 8 Old 02-02-2014, 04:09 PM
Ontario Trucker's Avatar
Thx for the info here guys, much appreciated
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
