Edge insight PID - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-11-2014, 09:44 AM Thread Starter
Garage
Edge insight PID
I would like to know if the insight cts will monitor EGT's with the stock sensors.
Also is it able to do a man regen on a 2011 6.7 L .
Dpica15 is offline
post #2 of 8 Old 01-11-2014, 04:55 PM
Randy_270's Avatar
Quoted: 2 Post(s)
According to the website it'll monitor the following:
Ambient Air Temp, Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed, Dist. Between Regens, Dist. Since DTC Clear, Dist. Since Regen, DPF Pressure, DPF Soot Mass, DTC Count, EGT Post DPF, EGT Pre DPF, EGT Post Turbo, EGT Post SCR/Pre DPF, Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, Fuel Level, Fuel Rate, Gear with Reverse, Gear with TCL, Intake Air Temp, Manifold Abs Pressure, Mileage Coach, MPG Instant, MPG Average, Nox PPM, Regeneration Status, Reductant (Urea) Level, Time 0-60, Time 1/4 mile, Torque, Torque Solenoid Pressure, Trans Temp, Turbo Boost
As for the manual regen, I can't answer that but I have a good guess that no you can't do a manual regen with it.
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #3 of 8 Old 03-18-2014, 08:49 PM
79_bronco's Avatar
Not sure if anyone ever answered this for you but it does have a manual regen.
I have only tried it once but it makes the RPM go up to about 2K+ and it starts spewing out white smoke instantly.
I wouldn't do it in your driveway unless you want to hose it off afterwards.
2012 F-250 Lariat Crew Cab Short Bed 4x4 FX4
Ranch Hand Front and Rear
30in Rigid E Series Light
Bilstein 5100 Series Shocks
Truck Cover USA American Work Cover with Toolbox
Kenwood DNX570HD Head Unit
79_bronco is offline
post #4 of 8 Old 03-20-2014, 06:55 PM
HighHP's Avatar
Where did you find the manual regen option? And yes cts will monitor all 4 egt sensors
2013 - F350 CCLB. - 40" Lift on 40s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #5 of 8 Old 03-20-2014, 07:11 PM
79_bronco's Avatar
It is under the diagnostics menu.
post #6 of 8 Old 03-21-2014, 04:15 AM
HighHP's Avatar
Cool thanks, Ill have to check that out, although the less regens the better I did notice at one point with a ton of city driving my dpf load got up to about 95% and my mpg went to ****. This would have been good right about then. For some reason mine seems to regen based on distance traveled, I can pretty much expect when its going to regen, atleast within 100 miles, which doesnt make sense to me because driving conditions are constantly changing...
HighHP is offline
post #7 of 8 Old 03-21-2014, 05:59 PM Thread Starter
Garage
Thanks for the reply's. Installed my cts this week.i am monitoring egt1 and 4.
What king of temperature are you seeing at normal driving conditions?
Dpica15 is offline
post #8 of 8 Old 03-21-2014, 06:15 PM
HighHP's Avatar
i monitor 1 and 4 to, regular city stop light driving i see 450-550 on 1 and 4 is usually 50-75 less, if I do a WOT run through a few gears I can see around 650-675 on 1 and usually 4 is pretty close to it if not equal. Never seen anything higher then 700 yet. Regens you can see 1000, that gets exciting.
HighHP is offline
The Following User Says Thank You to HighHP For This Useful Post:
Dpica15 (03-22-2014)
