New Ford Guy - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-11-2014, 07:55 AM Thread Starter
Quoted: 8 Post(s)
New Ford Guy
Hey Guys
Well I am in the process of ditching my 2011 Cummins and am picking up a 2014 Ford F-350 Platinum (Black) on Monday. This will be my first Ford, I had 2 Duramaxs and 1 Cummins prior to this. I am looking forward to trying out this new truck and hopefully it does not disapoint me ! I have been doing lots of reading on here already and already have a list of stuff to do to the truck. As I have been on previous forums I know the value of the "search" button but am looking for some info I cannot find.
If someone out there could tell me if the following features from H&S are available on the XRT for the Fords as they were with my Ram that would be great. I looked on their website but I heard this tuner is relitivly new for the 14's so I am not sure if it is up to date.
So do all these options work on the Fords as well ?
TPMS: Enable / Disable the Tire Pressure Monitoring System.
Optical Chirp on Lock: Enable / Disable the parking lights flashing when locking the vehicle.
Horn Chirp on Lock: Enable / Disable the horn chirp when locking the vehicle.
Set Headlamp Delay: Enable / Disable the headlamp delay.
Accessory Delay: Enable / Disable the shut-off delay of your radio and accessory system after the key has been turned off.
Fog Lights W/High: Enable / Disable the fog lights staying on when high beams are being used.
Daytime Lights: Enable / Disable the daytime running lights.
Seat Belt Minder: Enable / Disable the chime for the drivers seat belt system. This feature will not disable the seat belt light.
Thanks in advance
14PlatinumBlack is offline
post #2 of 12 Old 01-11-2014, 08:01 AM
Originally Posted by 14PlatinumBlack View Post
Hey Guys
Thanks in advance
Which model xrt do you have?
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #3 of 12 Old 01-11-2014, 08:10 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Welcome Aboard! Lots of useful information here to answer all your unanswered questions.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #4 of 12 Old 01-11-2014, 08:11 AM Thread Starter
Quoted: 8 Post(s)
I have not picked one up for this new truck yet and the one for my Cummins will be staying with it when it goes.
post #5 of 12 Old 01-11-2014, 08:12 AM
Trading our selling outright?
Brett
post #6 of 12 Old 01-11-2014, 08:13 AM Thread Starter
Quoted: 8 Post(s)
Trading, it has to stay in so it does not throw codes as it is fully deleted.
post #7 of 12 Old 01-11-2014, 08:45 AM
Are they beating you up on trade. As far as I know they cannot resell it deleted. I've had several friends trade in deleted trucks and they were charged 3k to return it back to stock. If you have your dpf I would sure recommend swapping it back on. That's what I did.
Brett
post #8 of 12 Old 01-11-2014, 08:56 AM
brendan.9's Avatar
Hey Guys
TPMS: Enable / Disable the Tire Pressure Monitoring System. I know the mini maxx does this i'm sure the xrt does as well
Optical Chirp on Lock: Enable / Disable the parking lights flashing when locking the vehicle. not sure on this but never heard of it
Horn Chirp on Lock: Enable / Disable the horn chirp when locking the vehicle. Not sure on this one either just click it once to look and the horn doesn't go off.
Set Headlamp Delay: Enable / Disable the headlamp delay. You can do this in the truck screen from factory i'm pretty sure
Accessory Delay: Enable / Disable the shut-off delay of your radio and accessory system after the key has been turned off. Not sure on this one either but did find out you don't need key in ignition and the doors can be open and you can turn on the radio not sure for how long.
Fog Lights W/High: Enable / Disable the fog lights staying on when high beams are being used. Theres a trick to this one somewhere on here do a search should find it.
Daytime Lights: Enable / Disable the daytime running lights. Don't think you can do this one but better to have the drl on they only turn on when you put it into gear.
Seat Belt Minder: Enable / Disable the chime for the drivers seat belt system. This feature will not disable the seat belt light. This is in your drivers manual under belt minder it tells you how to disable it very easy to do.
Thanks in advance
Hope this kind of helps lol
2013 F350 5" straight exhaust, Mini Maxx, CAI, H&S egr delete
03 SVT Cobra Whippled 632 rwhp 572rwtq Torch red 10th Anniversary coupe.
brendan.9 is offline
post #9 of 12 Old 01-11-2014, 02:56 PM
PSDJohn's Avatar
Brett
Ive seen trucks on lots advertised as being deleted.
2011 F250 XLT SCLB FX4 35k miles
H&S XRT Pro, Diamond Eye 4in straight pipe, 6in MBRP tip, S&B CAI, Edge Insight CTS, H&S egt kit.
Readylift stage 3 2.5in, 20x10 -24 Fuel Hostages, 35/12.50r20 Toyo MTs, Recon Cabs and Mirror lights.
Back Rack, TSC toolbox, Realtree seat covers.
PSDJohn is offline
post #10 of 12 Old 01-11-2014, 02:58 PM
powerstroke8994's Avatar
I can tell u one thing u won't be disappointed. Traded from 10 to 13 dodges then traded the 13 dodge in on a 14 white platinum. I love it. Love the pecan interior.
Sent from AutoGuide.com App
2014_F-250_Platinum
SOLD-2010_48re
SOLD_2013 MEGA_g56_laramie_Loaded
2002 F-350_lariet_
CUMMINS & MAXXFORCE
Powering Americas Future
powerstroke8994 is offline
