Holy Pyro 1 craziness! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 12-25-2013, 06:54 PM Thread Starter
Ryan2012F350's Avatar
Garage
Ok guys. Been doing some reading and everything turns into an infomercial for egr deletes. Just a quick answer if y'all have time please.
Truck is a 12 F350. Have minimaxx installed with high sulphur tuning. Just put a 5" flo pro on no muffler no bungs.
I just zip tied up all the factory exhaust sensors.
Quick rop around the block and she's full time defuel due to pyro 1. Climbed quick to 1500-1800 so I just strolled home.
Is this a real number (doubt it)?
Is this going to wreck anything until I do end up doing a delete?
Thanks.
Sent from AutoGuide.com App
2012 F350... Problems so far: Rear pinion seal, rad split, U-Joints, Waste gate tubing TSB.
4.5" Carli Lifted, 2.5" Kings, 37" Toyoed, Carli bagged, Wireless compressored, 5th hitched, rigids on both ends, slip tanked, titan tanked, upfittered, 12v pumped. Last truck I'll ever own.
Ryan2012F350 is offline
post #2 of 12 Old 12-25-2013, 07:31 PM Thread Starter
Garage
Like this! Trucks been off half an hour. Holy Pyro 1 craziness!-imageuploadedbyautoguide1388028683.629573.jpg
post #3 of 12 Old 12-25-2013, 08:30 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
No way the exhaust is still 2000 degrees after sitting for 30 minutes.
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #4 of 12 Old 12-26-2013, 06:39 AM
2013F250Tank's Avatar
What tune, pyro source selected (in MM settings) and prob do you have installed? Example... h&s tunes use the EGR prob while SPE and others use prob from exhaust.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #5 of 12 Old 12-26-2013, 07:35 AM Thread Starter
Garage
Pyro source with the crazy temps is Factory, H&S Shows 0.
Been doing some reading here, looks like with DPF deleted and no EGR delete I have no EGT probe at all and those numbers are total crap.
Will wait to turn it back to defuel at 1450 once I do EGR delete and have a probe in the blocker plates.
Someone correct me if I'm wrong,
Thanks!!
post #6 of 12 Old 12-26-2013, 08:53 AM
mario a diangelo's Avatar
Nope your fine turn the defuel settings off on your mini until you do the delete it cannot read a temp so it assumes that temp......your fine mine did the same thing until I did the delete now it is only like 6-700
2012 F-250 4dr shrt bed red blk leather
6.7 tuned by eric
little more then stock
2003 f-350extra cab short bed - sold
built ford tough package
4"skyjacker up front stock rear
6"stacks/black
diy boost fooler
programmed
4"custom intake
all black 20's
on 35"xtreme mt's
mario a diangelo is offline
post #7 of 12 Old 12-26-2013, 08:54 AM Thread Starter
Garage
Perfect. Thanks dude.
post #8 of 12 Old 12-26-2013, 03:45 PM
Senderofan's Avatar
I mistakenly used the EGR probe with my H&S Black Maax. Had really bizarre readings like you're getting. Switched to a probe from the exhaust and all was well.
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #9 of 12 Old 12-26-2013, 04:04 PM
99powerstroke62's Avatar
Quoted: 56 Post(s)
^^^^this explains a lot haha
Tyler
2015 F250 CCSB Lariat- tuned/deleted
2011 Wilma F350 ECSB Lariat-
2006 Black Magic RCLB XL- In pieces
99powerstroke62 is offline
post #10 of 12 Old 12-30-2013, 05:08 PM
Recently, I did the mini maxx and exhaust. I would like to get the EGT's displayed on the screen. I only have the EGR unplugged now. What is my best route for EGR and "pyro"? Sorry, I'm also a truck noob and only knew about "EGT's". Best route cost effective btw. Thanks.
2012 F250 XLT CC SCORPION
2011 GG EVO X
eve-slow is offline
