CAT-Back Straight Pipe Duel Exit Exhaust - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-24-2013, 06:26 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Anybody seen a straight pipe from the catalytic converter to dual opposite-side exit (one exit each side) exhaust system or at least something similar? I'm thinking about this exhaust set-up, but I don't know much about exhaust.
Dantron is offline
post #2 of 7 Old 11-25-2013, 08:04 AM
Dr.Evil's Avatar
First off, it will be considered a "DPF-Back" exhaust on our trucks, as the DPF is in place of standard "Cats" found on gas powered vehicles.
I have this kit on my truck, which I am thinking is what your looking for:
http://www.summitracing.com/parts/mb...250-super-duty
Just an FYI, you really won't gain any performance or sound with this kit, unless you delete the DPF. It will be more for looks than anything else if you leave the DPF in place.
2011 F-250 Lariat Ex LB 6.7
2001 F-250 R.C. LB 7.3
Dr.Evil is offline
post #3 of 7 Old 11-25-2013, 10:14 AM Thread Starter
POWERCHOKER
Dantron's Avatar
So are you saying that there isn't a catalytic converter on our diesel trucks?
Dantron is offline
post #4 of 7 Old 11-25-2013, 02:53 PM
ucpa111's Avatar
Quoted: 7 Post(s)
Our trucks have a selective catalytic reduction system and diesel particulate filter. That massive refinery of an exhaust is what you see under our trucks. Yes, the DPF is like a cat in some respects. It catches the particulate. Truck goes into regen to burn off the particulate. The SCR doses the exhaust with urea to cause a chemical reaction with NOx emissions. This reduces NOx to nitrogen and water.
2012 F350 CCLB 3.55 ELD with 20s. Lariat package, Chrome, FX4, Clearance Lights, Rapid Heat, Two Tone, Upfitters, HD Alternator, 5th Wheel prep, Truxedo Lo Pro Tonneau. Linex. On board air and shocker XL train horns.
THIS THING ROCKS!
ucpa111 is offline
post #5 of 7 Old 11-25-2013, 04:17 PM Thread Starter
POWERCHOKER
Dantron's Avatar
Correct me if I'm wrong, but it was to my understanding that the order of emission control systems located under the truck went in the order of catalytic converter, selective catalyst reduction system (DEF fluid injection into pipe before DPF), Diesel Particulate Filter, then exit exhaust piping. When I used the reference, CAT-Back Straight-Pipe, I was implying that the DPF would be deleted.
Does anyone know if it is possible, or reasonable, to install a DPF-back Dual Exit Exhaust now, and after 36k miles, go back and delete the DPF and EGR systems just for the sake of warranty. Do you have to replace the DPF with straight piping or can you take out all of the filter and it can act as sort of a muffler?
Dantron is offline
post #6 of 7 Old 11-26-2013, 08:50 AM
Axis2011KR's Avatar
Quoted: 2 Post(s)
The entire restrictive emissions nonsense is all in one piece so it's an all or nothing sort of thing. You either fully Delete or go DPF-Back. Sounds like you're wanting to go full delete which requires a tuner that is delete capable in order to run that setup at all. MBRP makes a dual exit like you're talking about in a 4" for DPF back or for full delete.
It's easy to install a DPF back but other than aesthetics it won't do anything really. You'd be better off replacing the DPF with a straight pipe then hacking it up to be a "muffler" because then you're screwed if you're trying to get warranty work and don't have a functioning DPF to put back on and it would have terrible flow going from a 4" to an 8" then back down to a 4" exiting the DPF chamber. If you want you can get muffled downpipe back systems. The 4" downpipe back systems are quieter than the 5" for reference.
2015 F-250 King Ranch 6.7L CC FX-4
Fabtech 10" 4 Link with Coilovers/American Force Vector 22x12/Toyo MT 40x15.50x22
SCT+No Limit+FloPro
2011 F-250 King Ranch 6.7L CC 4x4 sold
H&S+S&B+Open Downpipe
Axis2011KR is offline
post #7 of 7 Old 11-26-2013, 10:08 AM Thread Starter
POWERCHOKER
Dantron's Avatar
Ah I see. I didn't think about the ability to put the functioning DPF back on for warranty issues. The only reason I was considering hacking up the inner DPF and leaving the DPF piping was if law enforcement wanted to visually inspect my exhaust system during a pull-over. I have no desire for a muffler. Thanks for the information.
Dantron is offline
