egr plugged in? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-13-2013, 04:01 PM Thread Starter
boatpilot's Avatar
egr plugged in?
OK guys...long story short
Very reputable shop in my area installed mini maxx street tuner with their custom tunes, 5" tbe, S&B, and was gonna delete egr but a bolt in the back of the unit was cross threaded from factory and I was advised by the tech that it was in danger of breaking so better to leave the unit in place unless I wanted to take a chance of having to pay for cab off and alot of other BS due to bolt breaking...I say Ok, how is this gonna affect the truck, he says just leave the unit plugged in and their tunes shut it down completely, assured me it was safe.
So I'm running the above equipment with the egr plugged in and not blocked off and have no pyro because I have no block off plates...getting conflicting information on the web as to what I should do about the egr? I'm not really that concerned about the pyro but need knowledgable input about the egr.
Thanks
2012 F350 KR
Carli 4.5 Performance, Machined Fuel Kranks 17", 37" Toyo MT's, H&S Mini with custom tunes, H&S Cac, S&B CAI, 5" FLOPRO, EGR/DPF delete, Full replacement front and rear bumpers, toolbox, and bedrails by South Texas Outfitters, Rigid LED's, B&W hitches...and this thing is finished!
boatpilot is offline
post #2 of 10 Old 11-13-2013, 04:48 PM
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
h&s tuner instructions say to un plug the orange connector on the egr...seen some threads that if going back to stock some have had egr codes...something to do with a stuck valve...so I assume that is why they say un plug that orange plug. even though its disabled it does weird things as it still has coolant and exhaust flowing through it. as far as a bolt being stuck...are you talking about the 10mm nut on the very back side? if so that only needs to be loosend a bit to take the harness that has a hook off. I made a write up about the egr delete I did and took a pic of the backside so you can see what your working on. I had zero issue getting any bolts out, they were not that tight....and if one was cross threaded I would still yank it out as it has no effect on the delete...other than you wouldn't be able to put it back on...even so once you broke a bolt you could get a tap and die or whatever you needed to fix the situation as you will have a ton of room once its out. I didn't see anything that could've went wrong on the delete that would've required a cab off... I am not a diesel expert by any means...I have done all of the work to my truck in the last 2 months listed in my sig by myself but had an extra set of hands in my father in law and a buddy. I hate to say it but I think your reputable shop is either being lazy or chicken **** cuz if I can do it...anybody can. if you look in your pipes and manifold the **** in their will make you want to yank as much of that stuff off as soon as possible.
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #3 of 10 Old 11-13-2013, 05:15 PM Thread Starter
boatpilot's Avatar
I'm not sure what bolt it was but it couldn't have been the one on the back as they didn't get that far. I'm at a loss as what to do because the main reason I started all this was to keep **** from exhaust getting back into my engine...I'm tempted to get the kit from them and try it myself...everything else is done but the egr and truck runs good. So even though the tuner turns the egr off exhaust is still flowing through it just at a slower rate or what?
2012 F350 KR
post #4 of 10 Old 11-13-2013, 05:26 PM
jacobdewey's Avatar
I'd recommend contacting H&S to see what they have to say about it. Just my $.02
2011 CCSB, 20x9 -12mm Badlands, H&S, S&B, Katzkin, DDM 5k, 4" Zone, 37x12.50r20 Nitto Ridge Grapplers.
jacobdewey is offline
post #5 of 10 Old 11-13-2013, 05:30 PM Thread Starter
boatpilot's Avatar
Will be my first call in the morning...
2012 F350 KR
post #6 of 10 Old 11-13-2013, 06:55 PM
WoodBoy's Avatar
The EGR is supposed to be unplugged when deleted according to their instructions IIRC
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 10 Old 11-14-2013, 03:36 AM Thread Starter
boatpilot's Avatar
thanks for the replies guys...the more i think about this and the more research i've done the more inclined I am to having a long conversation with the owner of the shop this morning.
2012 F350 KR
post #8 of 10 Old 11-14-2013, 09:33 AM Thread Starter
boatpilot's Avatar
Again thanks for the replies guys and have talked to the shop owner, very positive conversation...will be taken care of
2012 F350 KR
post #9 of 10 Old 11-14-2013, 10:47 AM
LORD OF WAR
Curious to hear what they had to say...I assume they are going to move forward with the work?
87,96,04 F150 gone
"The War Wagon"
post #10 of 10 Old 11-14-2013, 10:53 AM Thread Starter
boatpilot's Avatar
Yes they are but with the understanding that if the manifold bolt breaks that is cross threaded it's gonna cost me a little more...hopefully it won't break and I'll be good but either way it's coming out.
2012 F350 KR
