EGR delete HELP - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-06-2013, 05:30 PM Thread Starter
99PSD-White's Avatar
EGR delete HELP
Guys I ordered a H&S EGR cooler/delete and i was looking at it and noticed one of the blocker plates have a hole in it for the EGT probe. Not sure what im supposed to do??? On H&S website the picture shows its supposed to come with no pyro hole.
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
post #2 of 5 Old 11-06-2013, 05:36 PM
Quoted: 10 Post(s)
You can install a pyro there with that bung. Use one of the pyro sensors from the DPF assembly and plug into the connector for the pyro on the EGR. It's just above and forward of the manifold plate w/ bung. You had to unplug it to remove the EGR. The Mini max will read EGTs from this sensor.
2013
F350 Lariat Ultimate FX4 CC LB SRW
jetskier is offline
post #3 of 5 Old 11-06-2013, 06:40 PM
What he said ^
blacknight is offline
post #4 of 5 Old 11-06-2013, 07:14 PM
PowerStrokePete's Avatar
Make sure you use the sensor out of the DPF. When I did the EGR delete I used a sensor that was in the one pipe on the right of the EGR and I was getting all weird numbers on my mini maxx. I switched it out for a sensor from the DPF and everything is working good now.
2011 F-250 SCLB XLT 6.7 Powerstroke
-H&S Minimaxx
-H&S EGR Delete
-Flo-Pro 5" exhaust
-Airaid intake
-Fisher 8.5' Xtreme V SS
-OUO traction Bars
-Dick Cepek DC-2, 35x12.5R18 Toyo A/T II
PowerStrokePete is offline
post #5 of 5 Old 11-07-2013, 02:12 AM Thread Starter
Excellent. I was reading something about using the Pyro from the DPF awhile back but just had the ask the question because it doesnt say anything in the instructions.
